Air suspension issue code c1762
Old Sep 27, 2023 | 12:42 PM
Jcmm's Avatar
Jcmm
2nd gear
Default Air suspension issue code c1762
Hi everyone,
I ran into an issue and no idea how to go about this as my general mechanic said it's beyond his expertise but my last resort is to go to Lexus and pay arm and leg.
Rear air suspension does not want to exhaust it's air or dampen as it goes over bumps and humps. The code I'm getting is C1762
"With the exhaust valve activated, the vehicle does not go down to the standard vehicle height after 6 minutes have elapsed.
Troubled areas
- air tube
- front height control valve
-rear height control valve
-height control compressor
Anyone experiencing this and where exactly is the problem?
Old Sep 27, 2023 | 01:20 PM
Anfanger's Avatar
Anfanger
I would start with height control valves.
Old Sep 27, 2023 | 03:06 PM
swfla's Avatar
swfla
This is a computer run vehicle. Techstream or similar diagnostic tool is almost required for diagnosing and repairing operations like this. Do you have it or a shop that does?
Old Sep 27, 2023 | 03:28 PM
Boykie's Avatar
Boykie
This code will set (obviously) if you run engine while car is on lift. It clears after couple of ign cycles, if vehicle is back on the ground. If it is and still this code is set - further diag is required. Ideally you get factory service manual and use DTC diagnostic chart for this dtc from there. It's checking air tubes, wiring etc. Your solenoid valve in the back may very well be bad. But replacing isn't super easy DIY thing.
lasearcy1
Apr 12, 2023 12:17 PM
ARS
GX - 1st Gen (2003-2009)
Mar 31, 2017 02:22 PM
vranish1
Nov 22, 2016 10:29 PM
majujose
Jun 21, 2016 09:12 PM
oldkystude
Jun 21, 2016 03:30 AM
