A/C startup delay -- recirc servo problem ?
Old Jun 26, 2023 | 11:03 PM
mmsharma's Avatar
mmsharma
5th Gear
Default A/C startup delay -- recirc servo problem ?
2007 Lexus Ls460
Problem started after car battery was dead for several weeks during Covid.
Symptom: On starting car, there is a repeated plastic-against-plastic sound (one click every 2-4 seconds, regular) from passenger side left foot area of the dash.
The clicking goes on for a few tens of seconds. During this time, the A/C button is lit, but the A/C is not on and other the A/C buttons (recirculate, etc) are also not functional. When the clikcing stops, all A/C button are off. Now, I can press the A/C button and turn it on, have to set the temperature each time, and can use the other buttons as well. A/C works.
Over time, the period for which the clicking sound lasts grew longer and longer.
As of last week, the clicking sound goes on for minutes and at the end, I can't turn on the A/C.
From my google searches, I have come to understand that this is a rare but known problem. It seems that the sound is from two servo motor arms colliding with each other and that these are part of the recirculate vent mechanism. Apparently, the servo motor is not properly initialized -- the motor is in one position, while the computer thinks its in a different position. So, the computer tries to move it to some position, but fails to do so. Until the computer gets the correct signal from the servo, it wont let user operate the A/C. Something like that.
Does anymore know more about this problem and its solution ? Is there a way to properly initialize the servo ? If I am happy with the A/C being permanently in the "recirculate" mode, is there a way to work around this problem ? Will resetting the ECU do it ?
related youtube video:
thanks,
mmsharma
Old Jun 29, 2023 | 07:17 PM
Sherl's Avatar
Sherl
Message me I will send you the LS repair manual
Old Jun 30, 2023 | 09:30 AM
trogdor113's Avatar
trogdor113
If Sherl is sending you the manual, check out the "check mode" detailed in the A/C system section. If you press and hold "AUTO" and the circulation mode buttons while turning the car on, the HVAC system will go into a self-diagnostic mode. Even if you don't have Techstream set up, you can use this to iterate through the servos in the ducts to try and isolate where the problem lies.
The servo's don't just randomly get mis-calibrated though; the only way this could happen would be a physical blockage in the duct, or the gears wearing or breaking. I'd be surprised if running the initialization function alone resolved the problem. Even in the video you linked, the guy mentions that the most common servo failure, the circulation control, is caused by people forcing the door open for filter replacement. If it's physically broken, no amount of initialization is going to fix it.
Strange that the system is completely shutting off though. If you want to run the initialization then you need Techstream, and if you have that you can check the specific codes being reported by the A/C amplifier to see what it thinks is happening.
Old Jun 30, 2023 | 09:34 AM
Sherl's Avatar
Sherl
Exactly. Mine has it broken because people didn't know how to change cabin filter and ended up with replacing servo that actuated the door
Old Jul 23, 2023 | 09:35 PM
mmsharma's Avatar
mmsharma
5th Gear
Folks, all I needed was a "AC SERVOMOTOR INITIALIZATION". My friendly mechanic put it on his OBD scanner, but found no codes at all. I nudged him to explore a bit more and we came across the above function. Pressed the button, restarted the car, and everything works normally.
Thanks for your help.
Old Jul 23, 2023 | 09:55 PM
mmsharma's Avatar
mmsharma
5th Gear
This problem and solution is also mentioned in the following thread: https://www.clublexus.com/forums/ls-...em-solved.html
Old Jul 24, 2023 | 06:54 AM
swfla's Avatar
swfla
I've seen quite a few threads where a damaged gear was found to be the issue. Glad your's wasn't.
aymaddemir
18
Feb 24, 2020 11:05 AM
durian
May 8, 2019 10:46 PM
nievjohn
Nov 8, 2011 11:04 AM
LS_4Will
Mar 26, 2004 06:20 PM
alexus
Aug 22, 2003 08:35 AM
