Srs airbag on
Old May 31, 2023 | 09:10 PM
Rubencillo's Avatar
Rubencillo
2nd gear
Default Srs airbag on
After a small bump I got the warning about airbags pull to side shut off the engine started again no warning put scanner and nothing no codes !! What could trigger this 🤔 😳
Old Jun 1, 2023 | 01:17 PM
trogdor113's Avatar
trogdor113
Which scanner are you using? Airbag systems probably won't show up with a standard OBD tool; you need a professional scanner (Autel, Bosch, Snap-On, etc.) or TechStream on a computer to get a full diagnosis
Old Jun 1, 2023 | 01:22 PM
Anfanger's Avatar
Anfanger
Maybe a sensor on one of the seats got triggered. But if there are no error codes, there is not much you can do.
cyclet
Jun 16, 2021 04:13 PM
damndanny
Build Threads
Sep 15, 2017 01:17 PM
O. L. T.
Sep 7, 2010 09:09 AM
shmelvin
RX - 1st Gen (1999-2003)
Aug 3, 2003 10:53 PM
