2010 Driver Side Mirror Replacement Options
Old May 27, 2023 | 05:34 AM
Leungsta's Avatar
Leungsta
Default 2010 Driver Side Mirror Replacement Options
Hi all, new to the forum as I just picked up a 2010 LS460 AWD.
I tried researching this but could not find a firm answer. My driver’s side mirror needs replacement (mirror only), is there a replacement part (OEM or aftermarket) that can be purchased?
I had found on Amazon a mirror overlay which you can install over the existing one but I’m not keen on that option.
thanks
Old May 27, 2023 | 07:36 AM
swfla's Avatar
swfla
Ebay is usually a good source for the glass replacement. Used is OK. Plus there's buyer protection.
Old May 27, 2023 | 10:31 AM
Leungsta's Avatar
Leungsta
Only glass replacement that I have been able to come across is 2013+. Would you have a link?
Old May 27, 2023 | 12:29 PM
swfla's Avatar
swfla
One will eventually show up on Ebay if you can wait. Depending on price, maybe a complete mirror is an option for you. Just remove the mirror. You could even resell the remainder. Just trying to think outside the box.
Old May 27, 2023 | 03:00 PM
Protholl's Avatar
Protholl
https://car-part.com/
Old May 28, 2023 | 07:09 PM
Leungsta's Avatar
Leungsta
Originally Posted by Protholl
thank you sir, did not realize this site existed !
Old May 28, 2023 | 07:44 PM
swfla's Avatar
swfla
BTW, you likely have heated and photochromatic glass. Be aware that not all replacements will have those features.
Old May 29, 2023 | 02:58 AM
Leungsta's Avatar
Leungsta
Thanks! I’ll check it out
Old Jun 1, 2023 | 08:59 PM
Leungsta's Avatar
Leungsta
Update, ended up buying an entire side mirror that comes with the mirror that I need. Anyone know if I absolutely need to swap out the entire side mirror or is there a way to pop out the mirror and replace? Tried searching but haven’t found anything
Old Jun 2, 2023 | 04:31 AM
Dave144239's Avatar
Dave144239
You can easily pop out the mirror glass. Just be careful, because the connectors for the dimming/heating functions are attached to it.
This isn't the best video, but it shows how easy it is. I used a plastic prybar instead of fingers.
I'm replacing both door mirrors, but I couldn't get the right color, so I'm in the process of respraying them before I install them.
Old Jun 2, 2023 | 07:27 AM
swfla's Avatar
swfla
The mirror does snap out with effort. Press it back in on all four corners at once. As mentioned, watch the wires.
Old Jun 2, 2023 | 10:12 AM
Boykie's Avatar
Boykie
In this order. This is for 13+ but should be same across whole range. Yes, bugger to pop out intact, be extra super duper careful. If never removed glass snapped in pretty tight.
Old Jun 2, 2023 | 02:46 PM
Leungsta's Avatar
Leungsta
Thanks all! I’ll be attempting this soon and will report back
Old Jun 3, 2023 | 09:01 AM
Dave144239's Avatar
Dave144239
I did it on the two new mirrors I got, and it was easy enough. Just be gentle and you should be fine.
lexman52
Feb 3, 2022 07:39 PM
SkyKing901
RX - 3rd Gen (2010-2015)
Sep 7, 2019 06:43 AM
d7moore
Jun 11, 2018 09:10 PM
