Steering Rack Problem
Old Aug 8, 2023 | 03:58 PM
  #31
Boykie's Avatar
Boykie
Just torque calibration and vgrs initialization. Techstream does it.
Old Aug 9, 2023 | 06:25 AM
  #32
Jpeterski's Avatar
Jpeterski
4th Gear
I don't have tech stream. Does this prevent me from installing it or can I take it somewhere after install to be programmed?
Old Aug 9, 2023 | 06:46 AM
  #33
Tec80's Avatar
Tec80
Originally Posted by Jpeterski
Does the rack need to be programmed after install or is just plug and play?
Plug and play. No calibration required.
Old Aug 9, 2023 | 07:41 AM
  #34
Boykie's Avatar
Boykie
Please, Tec80, do what FSM tells. Torque sensor cal in EPS system. Your steering will improve even more.
Old Oct 28, 2024 | 11:47 AM
  #35
LexusWes7's Avatar
LexusWes7
4th Gear
Originally Posted by Tec80
Problem found!
Root cause: contamination by water intrusion (R boot and wiper seal both failed to keep water out of the rack innards).
The rack with the right side endcap removed - note the rust:
After removing the motor housing (hold the housing, lift the whole thing and smack it a few times hitting the end of the rack shaft on a piece of wood on the floor) - again, note the rust:
Beads of water are visible on the winding endcap, and corrosion on the com pads (or whatever they are called, it's a brushless motor):
And I was able to duplicate the "old-school roller skate wheel bearing" noise, because water got into the ball screw and corroded the ball bearings (rack is toast). I attached a video of the noise.
I ordered a new rack from Wesley Chapel Lexus, $2062 shipped. At least I found the issue and determined that it wasn't easily fixable. Hope this helps someone diagnose their noise! Now I have a new paranoia about the right side rack boot and wiper seal......
In the video, you push the rod inwards, when you start to pull it out it makes a "Click Click" (two clicks). What Causes This?!?!? I replaced my front axles (2011 LS460) and now my steering makes the Click noise, depending on how far I turn in certain directions.
Can anyone diagnose what is making the Click noise? It sounds exactly like the click noise from the video attached by OP
DGOON
Nov 12, 2015 11:36 AM
brainsurge
Suspension and Brakes
Nov 6, 2014 07:20 AM
andyman32
Mar 3, 2011 12:50 PM
amul
Jul 10, 2006 03:33 PM
