Bank 1 can shaft positioning sensor
Old Mar 21, 2023 | 11:07 AM
Smooth1ner's Avatar
Smooth1ner
Default Bank 1 can shaft positioning sensor
Does anyone know where this is located. I pulled codes and that what wrong and why it won’t start. 07 Lexus ls460 base model
Old Mar 21, 2023 | 11:08 AM
Boykie's Avatar
Boykie
What code? There are 2 per bank + 1 extra.
Old Mar 21, 2023 | 11:10 AM
Smooth1ner's Avatar
Smooth1ner
All it said was cam shaft position sensor bank one. Where are they both located I’ll replace both
Old Mar 21, 2023 | 03:47 PM
Please try reading the code with a better scanners since it will tell you exactly what sensor you need to address
Old Mar 21, 2023 | 04:44 PM
swfla's Avatar
swfla
Will he need tech stream or similar after replacing sensor? I'm not sure if this is a simple swap or requires "programming".
Old Mar 21, 2023 | 04:47 PM
Boykie's Avatar
Boykie
Nah, of course not. It's just number of sensors and amount of possible DTCs - that makes diag less than straightforward for cam sensors (aka vvt sensors).
Old Mar 22, 2023 | 01:56 AM
lwphat66's Avatar
lwphat66
So here is the background. I had a cam shaft positioning sensor go out on me well I was driving. I lost all acceleration and eventually ability to start. I have replaced the sensor but the car still won’t start. It turns over like it wants to start but doesn’t. Any suggestions?
Which one(s) did you already replace?
https://www.clublexus.com/forums/ls-...l#post11467140
https://www.clublexus.com/forums/ls-...l#post11172459
https://www.clublexus.com/forums/ls-...eleration.html
Rbeeber
Dec 2, 2018 08:42 PM
mortirius
Jul 28, 2012 03:40 PM
Crown
Mar 15, 2012 03:25 PM
00&02rx300
RX - 1st Gen (1999-2003)
Jan 27, 2010 06:17 AM
jmoonan
Maintenance
Dec 7, 2005 07:36 PM
