Electronic Ebrake Module Repair
Old Mar 5, 2023 | 02:17 PM
vegasvip's Avatar
vegasvip
10th Gear
Default Electronic Ebrake Module Repair
My electronic ebrake control module for my 2007 Lexus Ls460L in the trunk seems to have shorted out on the board and blew its fuse. Light on the dash says take to dealer. It looks like water has leaked in and shorted it looking at the calcium build up on the board, I guess its a common issue in these cars. I was looking into buying a used one on Ebay for around $200 but then I have to get it programmed to the car which may be pricey from the dealer. I found a company in New York called G7 Computers who repairs vehicle computer modules and says they can do it for $275 and no need to reprogram after re-installing, has anybody used this company before or does anyone know of a company a little bit closer to Vegas that does the same type of work?
Any help would be appreciated!
Old Mar 5, 2023 | 05:49 PM
jdanielca's Avatar
jdanielca
Who advised you that the ecu needs programming to the car ?
Old Mar 5, 2023 | 08:07 PM
vegasvip's Avatar
vegasvip
10th Gear
Ive been researching on clublexus and apparently if i swap with a used ebrake module that it needs a techstream or dealer to reprogram it to my car. see below
Old Mar 5, 2023 | 09:41 PM
swfla's Avatar
swfla
You can go to independent repair shops that have the tool and experience to program it for less money than a dealer. Just call a few places, tell them your needs and they will know if they can do it. Don't forget to address the leaking water issue too.
Old Mar 6, 2023 | 01:59 AM
Anfanger's Avatar
Anfanger
Yes, the manual says that you need to calibrate the module with w/ or w/o Techstream. W/ Techstream, the calibration is basically one click. W/o Techstream, it is a lengthy process.
Old Mar 6, 2023 | 03:40 AM
jdanielca's Avatar
jdanielca
ah he means calibrate, that’s not the same as program to the car, I was reading a thread about someone swapping it and he did mention some calibration and zeroing etc
Old Mar 13, 2023 | 06:55 PM
vegasvip's Avatar
vegasvip
10th Gear
I just got a used module in and going to install it tomorrow. I got a quote from the dealer and they said $275 plus tax so I'm looking at around $300. Anybody here in the forum that has a techstream in the Las Vegas area that can do it cheaper let me know, that would be awesome, if not I will just have the dealer take care of it.
hayko350
21
Dec 27, 2024 04:14 PM
Mltsui99
Hybrid Technology
Nov 30, 2021 11:42 AM
LANewsboy
Nov 17, 2021 02:04 PM
baihama
Lighting
Aug 22, 2012 12:38 PM
350z
Oct 6, 2003 01:32 PM
