Best head lights
Old Mar 17, 2025 | 06:32 PM
  #31
UCF30Jack's Avatar
UCF30Jack
3rd Gear
Default D2R LED bulbs? Any recommendations?
Originally Posted by jgscott
You guys should look into the new plug and play HID to LED bulb conversions. I'm guessing if you have HID's you already have projector lens. The LED can be as much as 40% brighter than the best HID bulbs. I was stuck for a long time thinking the HID's were great on some other cars I had that had HID's.
I also was hesitant due to hearing on the internet about cut of lines, blinding other on coming car, melting the projector inside, and so on. Tried the HID to LED conversion, not one problem at all. No one ever blinded, no one ever flashes me. Cut off was great. They are simple plug and play also.
Look up some good ones rated on Amazon and other comparison articles. They have them for Low beam and High Beam. I ordered a few diff ones to try about a year ago. Installed and tested at night. Some better than others. Settled on a good set that were so much brighter than the Hid low beam, and a diff set for high beam. The high beams ones light up the world. I made sure I got a set that fit and had the built in cooling fans. One set been in for 1 1/2 years zero problems.
any recommendations on a plug and play led bulb for the 01-03 D2r hid?
Old Mar 17, 2025 | 06:52 PM
  #32
RX469's Avatar
RX469
Which brand model are you using?
Old Dec 10, 2025 | 10:15 AM
  #33
intermec's Avatar
intermec
Does anyone know what the different between:
OSRAM Night Braker Laser XENARC (Next Gen) and
OSRAM Night Braker 220 XENARC
Are they the same? Which one is newer?
Old Dec 10, 2025 | 05:24 PM
  #34
LS430inDE.'s Avatar
LS430inDE.
I was curious as well. I bought the LASERs several months ago but haven't yet swapped out the ORIGINAL bulbs in my 2005. I didn't want to believe that light output dims over time, and I was obsessing with cleaning and polishing the headlights, etc. I remember when I first bought the car, how AMAZING the headlights were, as there was a very distinct LINE you could see ahead of you. Also, when the headlights swiveled one way or the other, you could NOTICE it! Now, my headlights are like a incandescent bulb behind an opaque lampshade!
Specifically, ChatGPT says:
The Nightbreaker 220's are the newer version.
They say:
"The Laser Xenarc are known for delivering a brighter, more focused beam with longer reach and a more intense light output compared to previous generations.
On the other hand, the 220 Xenarc bulbs are made for even more brightness, sometimes up to 220% brighter than halogen bulbs. They often focus on a whiter light and a wider beam pattern too.
Overall, the NB 220 tends to be the more advanced version, offering a bit more brightness and clarity compared to the Laser Xenarc."
Old Dec 11, 2025 | 04:36 PM
  #35
paulo57509's Avatar
paulo57509
I replaced both original D2S HID and 9005 high beam bulbs last year. The 9005 capsules become discolored because they spend most all of their life as DRL's at reduced voltage.
Old Dec 13, 2025 | 06:39 AM
  #36
alextv's Avatar
alextv
Was there a whole lot of difference in the brightness of both the low and high?
Old Jan 18, 2026 | 03:52 PM
  #37
intermec's Avatar
intermec
After replacing my wife's 2010 RX350 with Osram Night breaker, I am in the middle of getting bulbs for my 2003 LS430. One thing I am still not sure is D2R, D2S. Seems like they are different and the correct size should be D2R. Input from anyone? - D2R = Reflector‑type HID housings (your 2003 LS430 uses reflector headlights).
- D2S = Projector‑type HID housings (used in later LS430 years).
- They are not interchangeable because the base, shield, and beam pattern differ.
shawnlexus
15
Aug 25, 2010 05:20 PM
mercclk6
Jul 16, 2008 09:34 AM
louiegs400
Jun 16, 2008 09:33 PM
VipBoss
Jul 26, 2007 09:19 PM
El Captain
GS - 1st Gen (1993-1997)
12
Jun 6, 2007 06:44 PM
