Hey y'all I'm looking to replace a bunch of front end components. Please let me know if I'm missing anything while I'm in there... Front Lower Control Arms
48620-50050
48420-50050
Front Lower Ball Joints
43340-59125
43330-59125
Tie Rods
45503-59065 (x2)
Lower Control Arm Bracket/Bushing (From Lexus IS250)
48076-30030
48075-30030
48620-50050
48420-50050
43340-59125
43330-59125
Tie Rods
45503-59065 (x2)
48076-30030
48075-30030
Upper control arms. Each arm has 2 bushings and 1 ball joint.
Stick with genuine Toyota parts for everything. The aftermarket stuff is a crapshoot.
I want HardRace or Figs UCAs. Those are good, right?
Mainly need confirmation on the bushing bracket from an IS.
I have heard these aftermarket upper control arm units can induce NVH (Noise, vibration and harshness). I may be wrong, but this is just what I was told when I enquired about HardRace specifically
Yes any arms with anything other than the soft OE rubber bushings will transmit more NVH. On my GS3 and GX I didn't notice a difference with poly bushings but with heims I'm sure it will be noticeable since there is no dampening
The 555 sway bar links are OEM equivalents. You can get poly mounts for the front sway bar, search my post for the part number. Make sure you preload the suspension when torqueing to spec.
