Help! Ls430 engine cover!
Old Sep 13, 2022 | 11:18 AM
Rehzy's Avatar
Rehzy
10th Gear
Default Help! Ls430 engine cover!
Hello, I really find clublexus very helpful and useful! I am a newbie when it comes to cars but I do have a clean 06' LS430 with 86k miles anyways
my engine cover bolts got cut off
Anyone know the size of the bolt or where I can get them and also how tf do I take off the bolt? Its stuck! Lol
Thanks in advance!
Old Sep 13, 2022 | 12:47 PM
bradland's Avatar
bradland
https://parts.belllexusnorthscottsda...125650030.html
Old Sep 13, 2022 | 06:59 PM
ExiledWolf84's Avatar
ExiledWolf84
As Bradland said, you will need to replace the brackets, which are relatively inexpensive. The studs are either welded or pressed into the brackets, so there really isn't a good way to repair them if they break off.
Old Sep 13, 2022 | 11:14 PM
Rehzy's Avatar
Rehzy
10th Gear
Cmon there has to be another way aha
Old Sep 14, 2022 | 08:32 AM
oifish's Avatar
oifish
Old Sep 14, 2022 | 08:38 AM
oifish's Avatar
oifish
In all seriousness, I have something similar to this:
Thread Gauge Thread Gauge
. It comes in handy for finding bolt and thread sizes.
Old Sep 17, 2022 | 07:44 AM
ExiledWolf84
It's probably an M6 x 1.00 thread pitch, similar to license plate bolts
You could probably just drill the old ones out and slide a bolt with the jam nut into the slot. The cover is going to ride slightly higher with the jamb nut on top of the bracket, but probably wouldn't be noticeable.
Old Sep 19, 2022 | 11:06 AM
dan25man's Avatar
dan25man
Superglue the joint and BAM bolt fixed... in all seriousness possibly use J-B weld, or another appropriate cold welding solution and glue it back together...
Old Apr 29, 2025 | 05:44 PM
aidanahram's Avatar
aidanahram
2nd gear
Default Nut size?
I lost the nuts while working on engine with the cover off. I remember it was a 10mm, anyone know where I can find these?
Prefereably OEM
Old Apr 30, 2025 | 04:36 AM
JaySco's Avatar
JaySco
Prefereably OEM
It’s just an acorn nut. Get them at any hardware store for maybe 25 cents, or the Lexus dealer for a few bucks. Your choice.
Old Apr 30, 2025 | 08:09 AM
aidanahram's Avatar
aidanahram
2nd gear
Do you know the thread size?
Old Apr 30, 2025 | 10:41 AM
weldthedif's Avatar
weldthedif
i threw my engine cover away 5 years ago. I like seeing the 3uz
Old Apr 30, 2025 | 02:51 PM
JaySco's Avatar
JaySco
No. M6 was mentioned previously, sounds about right.
Old May 2, 2025 | 07:53 AM
Holden53's Avatar
Holden53
Prefereably OEM
go to the junk yard - cost is 3 bucks to get in - find a toyota / lexus and your done - they typically don't charge for these items other than the entry cost
weldthedif
Aug 5, 2024 09:36 AM
bud13
Aug 31, 2019 11:54 PM
daddykay24
Sep 27, 2013 06:34 AM
