Rare AC compressor replacement. Will this work?
Old Aug 12, 2022 | 01:24 AM
beercan's Avatar
beercan
Default Rare AC compressor replacement. Will this work?
I have a rare AC compressor on a 2004-2006 LS430. (The car was made for Arabic market, not US/EU) and AC compressor is a little different (the hoses that come to it are different - they both go on top). And the clutch works similarly as on 2001-2003 LS430 stops and then works again. 88320-50091 - my part number
My compressor works fine, but with with a lot of noise and vibrations when the clutch engages. It's so annoying when the car is parked and AC is running.
The clutch is NEW. So the problem isn't with it. And I can't find the replacement for the compressor itself / rebuilding also isn't an option.
So I've been thinking about installing the compressor from LS400. It has the same mounting bolts and places for hoses to run.
The only difference is that I have an additional valve on top that goes to the clutch and the one from LS430 doesn't.
Will this work? Or what other compressors can I replace mine with? Thank you!
My compressor (photo from the internet).
The valve has 2 wires - 1 goes to the clutch plug. Another to the plug that goes directly to the ground point after that.
LS400 compressor - the difference only is that it doesn't have that valve that mine has on top .
Thank you again!
Mkarb
Oct 18, 2019 04:02 PM
levinsoy
GX - 1st Gen (2003-2009)
Jul 10, 2017 03:38 PM
ipwn
Mar 11, 2013 05:08 PM
DRFT86
Jun 23, 2012 01:40 AM
RedPhoenix
Apr 14, 2009 05:22 PM
