Questions about the Mark Levinson
Old Jun 29, 2022 | 02:38 PM
usedname's Avatar
usedname
Default Questions about the Mark Levinson
I love the ML audio - it's not great for rock/metal, but for traditional and classical music, which is what I mostly listen to, it's excellent.
Some of my speakers buzz, and I wanted to replace them, but I'm wondering if that would ruin the sound?
Also, would I be able to disconnect the tweeters (because it seems like way too much work to replace them)?
Old Jun 29, 2022 | 05:43 PM
2KHarrier's Avatar
2KHarrier
Your best bet is to find good, used replacements and swap them out. The ML system is matched and the amp is a little sensitive to speaker ohm ratings.
The tweeters can be disconnected, but you'd have to open up the dash to get at the connectors. If you're in that far, might as well swap them out...
Old Jun 30, 2022 | 12:16 AM
BigBoomer's Avatar
BigBoomer
Speakers that buzz almost certainly need to be re-foamed.
I re-foamed my front speakers and the buzz is gone.
I used these 6" speaker foam rings.
https://smile.amazon.co.uk/gp/product/B07DDLBY96
Old Jul 7, 2022 | 12:25 PM
StanVanDam's Avatar
StanVanDam
I've refoamed my front left and front right speakers once, and subwoofer twice, using the kits from SimplySpeakers. No need to replace the entire speakers, aftermarket speakers don't match the factory signal calibration, and new speakers are rather expensive.
Replacing the tweeters "properly" involves removing the dash. You could probably hack apart the openings for an easier time, but it may not look original when you're done.
Old Jul 8, 2022 | 06:05 AM
JaySco's Avatar
JaySco
+1 on the Simply Speakers rebuild kits.
McMuffin
Jul 1, 2022 12:36 AM
unixgur007
Sep 23, 2008 08:03 PM
captaincru
17
Apr 9, 2008 08:38 PM
windfall12
Jun 29, 2007 07:56 PM
