Door trim peeling
Other alternatives: plasti dip, black touch up paint, body shop respray
Clean surface
Cut vinyl wrap so it is remotely the size (slightly larger on all sides)
Apply from top or bottom and smooth it out as you go (most amazon rolls come with an air bubble removal tool, but you could use something with a flat soft(ish) edge, or just your fingers)
Once it is applied and there are no bubbles, trim off the excess (carefully) with an x-acto knife or similar. Yes, in theory you will probably nick the glass or rubber trim on the edges, so don't do this on your brand new Ferrari
Sometimes using a hairdryer or heat gun helps get air bubbles out. Don't be afraid to peel back and re-apply as you go. A good 3M film is easy to work with and some of them even come with the clear wrap you remove when you're finally done. It's really easy, essentially you are just applying a sticker.
