Driver and passenger side door not locking/unlocking
Old Apr 22, 2022 | 07:53 PM
Socals430's Avatar
Socals430
10th Gear
Default Driver and passenger side door not locking/unlocking
How's it going guys, I am going to try and make this not as confusing as possible so hang in there with me.
I have a 2004 ML LS430, I love the car the only main issue is the lock and unlock button on the key fob only unlocks/locks the rear (drivers/passengers) doors and not the front, same with the unlock/lock button on the door panel. The only way to make sure both driver and passenger side front doors are locked is to manually push the lock button before closing the door when exiting the car. The front drivers side door will automatically (smart lock) unlock when approaching the car half the time, the other half I need to insert the key to unlock the door and reach over to manually unlock the passenger side door.
Has anyone experienced this issue before?
Thanks in advance for all the feedback
Old Apr 23, 2022 | 07:46 AM
911LE's Avatar
911LE
Your door lock actuator motors have failed. Common problem thats easy to fix. Cost is $7/door if you diy. Do a search as it's been covered hundreds of times.
Old Apr 23, 2022 | 10:16 AM
Socals430's Avatar
Socals430
10th Gear
Will do, thanks.
Old Apr 23, 2022 | 10:56 AM
Socals430's Avatar
Socals430
10th Gear
Just did a quick search and a bunch came up, any specific brand/model I should look for ?
Thanks
Old Apr 23, 2022 | 05:48 PM
Paulanth's Avatar
Paulanth
Default Door lock actuator motor
1.Motor is : Manuchi
FC-280PC-22125
2. Look under “ebay Door Actuator Motor”
3.vi.raptor.ebaydesc.com
4. YouTube for Do it yourself:
”2005 Lexus LS430 drivers
lock actuator Motor fix”
Let me know if u need any other info.
Old Apr 24, 2022 | 12:03 PM
teaa's Avatar
teaa
FC-280PC-22125
all four of my doors do not lock or unlock with the keyfob. The keyfob itself works though because the trunk release functions normally.
Would you recommend replacing the motors or could this be an additional issue since it's all four doors? It's been like this since I've owned the car, so I'm unsure when they went out
Old Apr 24, 2022 | 01:15 PM
Paulanth's Avatar
Paulanth
Replace one actuator motor.
If that fixes that door’s problem,
you have the answer?
Old Apr 24, 2022 | 03:50 PM
thellmer's Avatar
thellmer
Teaa...do any of the 4 doors lock or unlock using the manual arm-rest buttons? If they work with the arm-rest buttons but not with the fob, then it is a fob issue or ecu to fob issue, but if they also do not work with the door lock button on the arm rest then its probably all 4 actuators have gone out or else the driver's door ecu which controls all four door functions or a wiring problem with the ecu. Also check the door lock fuse.
Old Apr 25, 2022 | 01:06 PM
teaa's Avatar
teaa
None of the arm rest buttons work. Most likely not a fob issue then, thanks. Will be replacing one of the actuators first, if that doesn't work I'll check the fuses and start researching the door ecu
Old Apr 25, 2022 | 04:41 PM
thellmer's Avatar
thellmer
When you press the arm rest lock/unlock button or the fob do you hear anything at all? Even on my passenger door which won't actually complete the lock or unlock cycle, it does make the clump noise to let me know it tried. If you hear nothing at all I would look for the fuse first - hard to believe all four would be completely dead with no noise at all. If no noise at all I would suspect the fuse since that would indicate none of them are even getting power. Typically what happens is the little motor either strips or cracks the d-shape worm gear, or they simply bind from the motor not having enough power to complete the turns.
Old Apr 26, 2022 | 03:24 AM
BigBoomer's Avatar
BigBoomer
Don't forget that the Techstream settings may be set in different ways w.r.t. which doors open. See attached.
Unlikely that 2 doors would fail simultaneously and VERY unlikely for 4 to fail simultaneously.
Attached Thumbnails Driver and passenger side door not locking/unlocking-techstream-unlock.jpg
Old Apr 28, 2022 | 01:25 PM
Socals430's Avatar
Socals430
10th Gear
10mm or 20mm ?
Thanks
Old Oct 7, 2022 | 11:25 AM
Socals430's Avatar
Socals430
10th Gear
Finally got around to replacing the actuators on the front driver and passenger side door. They were extremely loud and lasted a day. Did I install them wrong or do you guys think the actuators fail? I purchased them from Amazon, link below
Amazon Amazon
Thanks for the feedback
Old Oct 10, 2022 | 02:49 PM
danielmew's Avatar
danielmew
I too have a 2004 LS. My rear passenger door lock has failed. I push the lock on the remote or on the door button, all the door locks but the rear passenger door click again and unlock. I can lock it from the inside, but it will not unlock when I engage the remote. If it is the motor, what length of shaft; 10 or 20 mm? What style of shaft; round-shaft, D-shaft or flat-shaft? Thanks,
GX - 1st Gen (2003-2009)
Jun 12, 2022 08:57 AM
SonicISF
Mar 18, 2017 06:53 AM
jwynn
Nov 20, 2016 05:44 AM
jlb5685
Apr 6, 2014 04:56 PM
gs300inky
Maintenance
Oct 5, 2004 02:48 PM
