Would these specs rim/tire fit LS430
I am looking at a set of 18 inch wheels, with the following tire specs:
front: 8.5J 52 offset, tire 245/45/18
rear: 10.5J 50.5 offset, tire 285/40/18
I have an LS430 from 2001. I think these would fit but perhaps there is someone that knows the max width for the rear tire.
I have 225/55/17 with ET45 now (stock 17 inch wheels). Rear tire would be around 55 mm more inwards if i calculated that right.
This link has the specs for the offsets for the model and year of your car.
https://www.hubcaphaven.com/c/423/le...eels_rims.html
I just watched a video of how to replace the studs.... it is much easier than i thought it would be... but i guess it would require some disassembly of the hub... i don't think it can be done with the hub on the car
IS350DMAR
10-17-13 06:35 PM
