battery change
Old Feb 10, 2022 | 01:03 PM
semar's Avatar
semar
Default battery change
Recently I read that some "modern" cars must be re-programmed if you change the battery.. When batteries get old the computer tells the alternator to up the charging . When a new battery is installed this higher alternator output can damage the electrical system. The new BMWs are the best example.
Does this apply to the 2001 LS 430?
I dud replace my battery (it lasted 13 years) with a new one, and I want to know if I did the right procedure
Old Feb 10, 2022 | 01:18 PM
LatinLS430's Avatar
LatinLS430
Your battery lasted 13 years! That's pretty crazy!
I only know that you might have to reprogram the automatic feature in your windows. There's several YouTube videos on the process.
Old Feb 10, 2022 | 01:55 PM
You shouldn't need to do anything except reprogram radio presets
Old Feb 10, 2022 | 10:14 PM
semar's Avatar
semar
I found out you do not need to re-program anything.
Even my Atoto S8 premium has a memory
thanks for all the inputs from the forum
naivelin
Oct 8, 2019 03:07 PM
Andyboy980
Dec 17, 2018 12:07 PM
vintagelex
Oct 24, 2014 01:32 AM
keskipper
Aug 12, 2012 08:29 AM
ted920
Jul 31, 2006 10:17 AM
