Negative cable
Old Dec 2, 2021 | 08:58 AM
LatinLS430's Avatar
LatinLS430
Default Negative cable
Hello,
Can you guys show how your negative cable looks on you LS 430. I recently got my LS and the negative cable looks like this:
The plastic cover won't close because of the wing nut. What would I need to make back to OEM again?
Old Dec 2, 2021 | 09:46 PM
teaa's Avatar
teaa
that bolt seems too long, find another one the same size thats shorter and get rid of the wing nut, not necessary
Old Dec 3, 2021 | 02:01 AM
BigBoomer's Avatar
BigBoomer
Looks the same as my Negative clamp but with a different bolt and nut.
The Positive uses a different much more complex clamp.
With a shorter bolt the black plastic cover should fit over it like this one (not my pic, found on Google Image Search)
Old Dec 3, 2021 | 05:43 AM
kos's Avatar
kos
Terminal is correct, bolt / wingnut is not.
Old Dec 10, 2021 | 08:24 AM
RoyHarvey's Avatar
RoyHarvey
3rd Gear
I have 2004 LS. your long (carriage) bolt and wing nut are definitely not OEM.
Little
May 20, 2018 05:07 AM
scottgolf
Apr 4, 2012 09:57 AM
Sulls
Dec 9, 2007 07:18 PM
encore888
Jan 6, 2006 05:34 PM
