Ls430 not detecting key fob
Old Nov 29, 2021 | 12:53 AM
Lexusls43o's Avatar
Lexusls43o
Default Ls430 not detecting key fob
Hi guys
Had a message on my dash saying batteries were low on my key fob. Changed the battery and now the smart key is not working. Any ideas of what it could be?
key fob buttons are working. Can lock/unlock/open trunk. Checked the smart key switch under the dash too.
Smart key light flashes green along with a red flash too and I get the message of 'key not detected' I can start the car with the fob in the ignition.
Old Nov 29, 2021 | 06:30 AM
BigBoomer's Avatar
BigBoomer
Duff battery? Did you test the battery with a voltmeter? If new should be at least 3.2V.
Even if the push buttons on the key work, I'd still check the battery.
I've seen weird behaviour with duff batteries in fobs before.
Old Nov 29, 2021 | 06:43 AM
Lexusls43o's Avatar
Lexusls43o
Thank you! I didn't check it with a meter. Will give it a whirl tomorrow and check again. Don't get the low battery sign anymore though just the key not detected sign
Old Nov 29, 2021 | 12:09 PM
TominPT's Avatar
TominPT
Your valet key (if you are using it) must be in the ignition to start the car. When I get key not detected message it usually means I have the valet key with me, not one of the regular keys.
Old Nov 30, 2021 | 09:47 PM
Lexusls43o's Avatar
Lexusls43o
Cheers guys. Turned out to be a duff battery. Worked a treat once I changed it!
ursnicu
Dec 31, 2018 06:17 AM
430
Nov 27, 2018 07:43 PM
Celsior21
Apr 25, 2014 01:49 PM
Arcturus
Mar 10, 2014 06:55 AM
FoxfireNC
Sep 22, 2013 08:13 AM
