DIY For Rear Wheel Speed Sensor? C0210 Code
Old Sep 13, 2021 | 07:05 PM
bmwahba's Avatar
bmwahba
Default DIY For Rear Wheel Speed Sensor? C0210 Code
Hey all,
My car has code C0210 and after having lexus scan the codes they recommend replacing the right rear wheel speed sensor.
I bought the sensor and since the dealer wanted $750 to do the replacement parts and labor, I'm curious if anyone has done this and can point me in a direction on how to DIY the replacement. I can't find any guides on how to do this, only replace the entire hub. The part I am replacing is part # 89545-50050
Can it be unbolted and swapped without major disassembly of the hub/brakes?
Any help please!
Old Sep 13, 2021 | 07:28 PM
911LE's Avatar
911LE
Super easy. Pull up on the front of the back seat bottom to release it and remove it. Remove the 4 bolts along the bottom of the rear seat back. Remove the 3 nuts along the top of the seat back, 1 behind each headrest, one behind the armrest trim. Pull the seat back forward to access the connector for the speed sensor. The sensor end is held in the hub by a 10mm bolt and there are a few more 10mm's holding the wire to the upright and wheelwells. You'll know where the are because the tabs are part of the wiring for the new sensor.
freddyboy
RX - 1st Gen (1999-2003)
Sep 11, 2016 05:19 PM
edwinbong
Jul 14, 2016 11:00 AM
Gs3500
Jan 20, 2016 09:16 PM
lex6883
20
Aug 19, 2013 07:48 AM
