Speed sensor
Old Dec 31, 2009 | 06:56 AM
lex6883's Avatar
lex6883
Default Speed sensor
I have a 2000 ES300. my speedometer, odometer, and cruise control are not working. the VSS on and off lights are on, abs light is on and check engine light is on. i checked the codes at autozone which told me it was the speed sensor. i changed that and the all of the above is still happening. i also checked the fuses. what do i do next?
Old Dec 31, 2009 | 11:43 AM
mmlex1987's Avatar
mmlex1987
After you changed the speed sensor, did you reset the computer either with the scan tool or by disconnecting the battery for 30 or so seconds? Did the speedo work after replacing the sensor?
Old Dec 31, 2009 | 12:26 PM
llcoolpass's Avatar
llcoolpass
Default sigh.... newbs....
i think he is saying that the problem, as defined above , is still happening, which if true I'm not sure would be solved by clearing a code.
which speed sensor is bad? this can mean 6 different things....
give the code number [duh] and exact name of the part you had changed......
let us know, especially mike deano, because he has an '00 and is going to remember a thread like this very well! haha
Old Jan 1, 2010 | 06:42 AM
GEORGE_JET's Avatar
GEORGE_JET
As you now realize, you cannot just read a code and start replacing parts. The codes are there to indicate what sensor to check. The proper way to troubleshoot error codes is to get the code number and then make the relevant tests. There are several speed sensors, it is possible you replaced the wrong one. It is also possible that the real problem is not the sensor. The problem could be the wire harness, or the ECM itself. So unless you want to randomly throw parts at it, you need to get the code and then inspect the circuit.
Old Jan 1, 2010 | 02:49 PM
llcoolpass's Avatar
llcoolpass
well there are 4 wheel speed sensors, 2 vehicle speed sensors
2010 oh no!
Old Jan 21, 2010 | 07:54 AM
lex6883's Avatar
lex6883
I replaced the speed sensor with the 2 terminal plug. to the left of the air filter. i was getting the P0500 code. and after replacing it i am still getting that code. i also have the trac control, abs, and check engine lights on on the dash. i did try to reset the computer and that did not work either. i cant find the other sensor with the gear on it.
Old Jan 21, 2010 | 07:58 AM
lex6883's Avatar
lex6883
http://shop.advanceautoparts.com/web...S_521816021___
This is the part i replaced
http://shop.advanceautoparts.com/web..._521808985___#
This is the one i bought the first time and could never find it so i returned it and was told that i had bought the wrong one.
Old Jan 21, 2010 | 10:03 AM
GEORGE_JET's Avatar
GEORGE_JET
Sorry to say, but the first sensor was the correct sensor for the speedometer. It should have three wires connected to the sensor, the one that you replaced appears to have only two.
Old Jan 27, 2010 | 12:37 PM
lex6883's Avatar
lex6883
yes the first one had 3 wires and the second one had 2. but i couldnt find the first one on the car. no one has diagrams. i called lexus and they wouldnt give me any info at all. they wanted me to bring it in for a $200 charge.
Old Jan 27, 2010 | 01:04 PM
GEORGE_JET's Avatar
GEORGE_JET
speedmeter.doc
This pic shows the location of the speed sensor
Old Jan 27, 2010 | 01:22 PM
MikeLex's Avatar
MikeLex
Attached is the DTC P0500 Inspection Procedure. As you can see, the first thing to check is open or short in VSS circuit.
File Type: pdf
Old Apr 1, 2010 | 07:30 AM
lexusGSfo's Avatar
lexusGSfo
Hey, I have a lexus GS400 and my speed odometer is not working. My VSS light is on and my abs light is on. I had the codes read and it gave me 4 codes. 3 speed sesors and the yaw sensor. Do anybody now where I can get the speed sensors from other than the lexus dealer. Please any suggestions on how I can fix my problem.
Old Apr 1, 2010 | 11:09 AM
dcapo's Avatar
dcapo
wow really a speed sensor will stop the speedometer, odometer, etc from working, how miles u got on it, id find a replacement, or check fuses
Old Apr 2, 2010 | 08:45 AM
lex6883's Avatar
lex6883
i got the two Auto Zone and Advanced Auto. im not sure if those are in your area. i still cant find the speedometer sensor even after looking at all of the diagrams.
Old Apr 2, 2010 | 08:46 AM
lex6883's Avatar
lex6883
oh there were 117,000 miles on it when the speedometer and odometer quit working
