Replace ML Sub with Pioneer
Old Sep 10, 2021 | 07:32 AM
mmzbrwan's Avatar
mmzbrwan
Question Replace ML Sub with Pioneer
Hi,
Please help me guys, can I install Pioneer subwoofer in ML system ?
I have LS430. And my ML subwoofer has only 2 wires and now I want to replace it with a pioneer OEM subwoofer but it has 4 wires. anyone know how to wire it?
Thank you
Old Sep 10, 2021 | 09:06 PM
caverman's Avatar
caverman
If you have the ML system you should keep your stock sub and just refoam it if you need to.
Old Sep 11, 2021 | 12:25 PM
mmzbrwan's Avatar
mmzbrwan
The stock ML sub has problem inside it and i have to replace it not refoam it. Can I use the pioneer sub as i have one?
Old Sep 11, 2021 | 12:46 PM
911LE's Avatar
911LE
No, you cannot. The Pioneer sub is a dual voice coil with 2 ohms of resistance. The ML sub has 16 ohms of resistance. It either won't work at all or it'll fry your amplifier, or both.
Old Sep 11, 2021 | 01:26 PM
mmzbrwan's Avatar
mmzbrwan
Thank you 991LE.
Old Sep 12, 2021 | 08:51 AM
Jabberwock's Avatar
Jabberwock
I think the sub on LS is 8 inch. Here are a few subs available on line that may work instead of paying crazy price for new ML sub - some of them may require a little custom mod and mounting but its usually not too difficult to get a new sub mounted. The Goldwood has 91 db sensitivity so it would be a little louder in the mix than the Dayton which is 85 db. On the other hand the Dayton is a little better qaulity speaker. My guess is that either one would be fine as a reasonable replacement speaker for a 15+ year old car. The OEM ML sub is not worth the extra cost.
https://www.parts-express.com/speake...inaldiameter/8
https://www.parts-express.com/B-C-8P...6-Ohm-294-5917
Old Sep 13, 2021 | 03:33 AM
BigBoomer's Avatar
BigBoomer
I have the Dayton in mine and it's a good match for the ML system once broken in.
At first you may have to turn the bass down one notch but after a few weeks of use I turned mine back up to the midpoint, so bass/mid/treble are all in the middle.
dtwins962
Jul 2, 2019 06:18 AM
Alpha9
Sep 2, 2018 05:53 PM
JM1995
Feb 20, 2017 08:25 AM
miniz
Jun 5, 2012 12:44 AM
ISFnFast
IS F (2008-2014)
21
Oct 13, 2011 07:20 PM
