Mark Levinson Issue
Old Sep 5, 2021 | 12:30 AM
hb7779's Avatar
hb7779
Default Mark Levinson Issue
Hi Members,
New member seeking help. My audio system has a very strange issue. I searched the forum but I was unable to find a similar issue. My radio controls, cassette player, CD does not work. The radio ***** don’t even have the backlight. Zero life. Steering wheel controls also don’t work. I can only slightly hear the radio. It is so faint as volume was set at .5. I can hear all the speakers and sub at that volume.
I have checked all three fuses (radio, tel and amp) and they all are fine. Not sure if I should be checking any fuses for ACC and On sources.
I desperately need help. I hope someone has experienced this issue and can guide me. I would greatly appreciate it.
thank you
Old Sep 5, 2021 | 08:46 AM
hb7779's Avatar
hb7779
Bump
any thoughts friends???
Old Sep 5, 2021 | 09:27 AM
Need a wiring diagram I'll try and find one or hopefully someone else will post. Kinda sounds like the head unit died.
What year is your car?
Old Sep 5, 2021 | 03:29 PM
hb7779's Avatar
hb7779
I am happy to report that I disconnected the amp and head unit for about an hour and when I plug it in all started working. Don’t know how long it will last but so far it’s working.
thank you for the reply. I appreciate it.
Old Sep 6, 2021 | 05:14 AM
BigBoomer's Avatar
BigBoomer
Sounds like it had corrosion on the connectors. If the problem recurs, clean the contacts of the connectors with a contact cleaner spray and then smear them with a dielectric grease.
There is also a known issue with the type of solder used on the circuit boards in the earlier LS430s so sometimes giving the amp a "thump" can get it working again.
Old Sep 6, 2021 | 07:06 AM
hb7779's Avatar
hb7779
thanks. I will keep it in mind.
OsLS400
Feb 1, 2021 08:56 PM
professora
Feb 3, 2019 10:29 AM
BOSS13000
Jun 1, 2017 06:22 AM
smp
Jan 12, 2015 10:21 PM
milellie11
Aug 27, 2010 08:11 PM
