Common motor oil leaks
Hi,
I have a leak in my 04’ ls430. Just curious, where have you guys been seeing most of the oil leaks? It’s leaking enough to where I see it on the floor. Just curious. I haven’t gone under yet to examine, but I’m sure there are many folks on this forum who would know the most common areas of leakage. I know the oil filter was placed on correctly, but any other spots?
thanks in advance.
thanks in advance.
Valve cover seals check to see if you can see oil on the exhaust heat shield both sides to do the passenger side you might have to remove the air box/ piping if you do see then u can tighten the bolts down cause they do come loose eventually
AichiBorn
Mar 26, 2021 04:59 PM
