The BIG stereo install
Old Jan 27, 2021 | 09:30 AM
Squirrel1's Avatar
Squirrel1
Originally Posted by ChopsGS
Yup. It isn't for sale.
did i try to buy it lol? I actually thought about putting a 8w7 up there with a box built under it
Old Jan 28, 2021 | 08:55 AM
ChopsGS's Avatar
ChopsGS
Haha... Just in case you were. LOL
Someone did an install of an 8w7 in the rear deck, free air. I was actually thinking about getting one, but the stereo isn't as big a deal for me these days (all that extra $$$ goes into my home system) as it was year ago, so decided on the Dayton Ultimax instead. Still a hell of a beefy sub and should do the job quite nicely. Of course, now I can't find the pic of that JL install on Google. Go figure.
Old Jan 28, 2021 | 09:24 AM
science's Avatar
science
Old Jan 28, 2021 | 09:35 AM
science's Avatar
science
Here ya go. I did the same thing....wanted a backup cam. Installed a regular screen and couldn't live with the glare due to my light interior color.
Components:
1. Kenwood DDX8906s DVD tilt
2. cheap $7 raw driver 6.5 front door
3. JL xd700.5 -> Hertz crossover -> front door and oem tweeter->oem rear doors->oem sub
4. Rockford Prime 500 2ch -> 12 shallow mount Pioneer that I had laying around.
Amps were gained with o-scope. I had to run speaker wires from HU and utilized all factory speaker wiring. I used DIN Rail terminal blocks and breakers. The terminal blocks are plug-on and makes configuration and routing changes very easy. This is my 3rd iteration of my system...this final one I was able to power the oem sub and shallow mount. I also had a Infinity 10'' perfect in their before settling on the shallow mount. The cheap o 6.5 actually sound pretty clean. I still have a set of Hertz tweeters that I plan to put under the existing tweeter grill, but I have zero time currently to run new wires to them.
This is mainly a SQ setup. I had planned to run my Rockford DSP but I don't think its necassary at the moment. I have a set of Dayton 3.5'' raw drivers that I love in my current Truck. Still trying to find a way to install them on the dash.
Old Jan 28, 2021 | 09:40 AM
science's Avatar
science
I also added a pocket where the cd changer was. It was a simple bolt-on to the BS kit. $10 on amazon. I routed my usb cables in there. Front cover as you can see is fully functional.
Old Jan 28, 2021 | 11:13 AM
Squirrel1's Avatar
Squirrel1
damn thats interesting i wonder what it sounded like
Old Feb 2, 2021 | 06:01 PM
Squirrel1's Avatar
Squirrel1
I have bought a head unit. Kenwood ddx9705s used off ebay its the same exact head unit i have in my tahoe so i figure it will be easy for me to test. 7" cd reciever with tilt screen and wireless android auto. I wanted the tilt because its kind of a low spot these mount in and i didnt want a bad viewing angle. Plus im too old to give up cd's!
Old Feb 16, 2021 | 07:06 PM
Squirrel1's Avatar
Squirrel1
More parts coming in
Old Feb 16, 2021 | 07:07 PM
Squirrel1's Avatar
Squirrel1
Feel the bass!!!
Old Mar 17, 2021 | 08:26 PM
Squirrel1's Avatar
Squirrel1
Couldnt find a distribution block like i wanted so i started making one
Old Apr 30, 2021 | 03:10 PM
Squirrel1's Avatar
Squirrel1
A little more progress. Ended up with a 500 watt mono, a 300/4 and 300/2 amps. Just finished making my power distribution block today
Old May 8, 2021 | 08:27 AM
Squirrel1's Avatar
Squirrel1
Still goin, bought a jl audio 10w3 im going to mount it so that its facing up under the rear deck firing under the hole for the factory 8" sub in a sealed box. Amp rack with all the electeonics will be under that and i plan on a cover for the whole thing so that when you look in the trunk all you will see is a false wall.
Old May 8, 2021 | 10:00 PM
WILLYumD's Avatar
WILLYumD
Keep us posted as to how you're going to build that.
"I'll build a box under the factory rear deck hole" has been my go-to-but-never-attempted-nor-achieved subwoofer pipe dream.
The amount of reinforcement I'd wager is involved to make the rear deck not rattle will be a feat.
My 10W3v3 is running at a measly 300W (2 Ohms) in a JL HO box sitting right under the rear deck and the rattle can be pretty atrocious.
Old May 9, 2021 | 12:19 PM
Squirrel1's Avatar
Squirrel1
a friend of mine thats done a lot of builds says i will want to wedge something like a thick yoga mat firmly between the rear deck and the box
Old May 14, 2021 | 06:34 PM
Squirrel1's Avatar
Squirrel1
For your viewing pleasure i present the circuit breaker i've been dicking around with for a week. There is a nutcert holding down the left side the double sided foam is just for cushion
