Do you have any suggestion on how to remove the rear door panel? I want to check my speakers and power window motor (it's only go down half way and stuck).
Got the double din in. Everything wired, backup cam done. That white dot is where i wanted to drill a hole for my bass **** but i couldn't bring myself to do it. Put it in the cubby hole instead. A little difficult to use but i'll probably get used to it
I used to have the **** in the same cubby as you... Considering the wide gamut of music that makes its way through my speakers, I needed the **** more immediately.
So I broke out the drill.
Bass ****, stereo power switch (I like a hard switch for resetting), illuminated exhaust cutout controls and the factory ECT button.
Wish the coloring matched, but, oh well.
If you do decide to drill, be careful. The front is laminated in a way that can crack pretty easily. Start small, blah blah blah. Thankfully, my holes are smaller than the bezels/**** so cracks are covered.
I bought a replacement on eBay for $25 just in case.
L12 wire 13 (brown) in the trunk junction box is what i tapped into to trigger the back up cam. Thanks to tyler z for that info. See attached pdf
i looked on ebay and cpuld only find the whole assembly for $80. Wanna sell me your extra one?
wow thanks you had far better luck searching for that than i did. Think i'll make a offer in the first one. If anyone can do it its me im a aerospace machinist i can drill a hole better than anyone but im still weird about drilling into this car haha
Starting to look at trunk layout. The box represents the 1 cubic foot fiberglass box i will have for the 10w3. Trunk is still going to be huge! The false wall will be behind the cover for the spare tire just as i had hoped
