Mirror question
Old Dec 18, 2020 | 09:31 AM
Forbidden's Avatar
Forbidden
Default Mirror question
Hi all
First I would like to thank all of you that provide excellent info on here as I have learned a lot and was able to do things that I probably wouldn’t.
my problem is
both of my door mirrors are hazy and it is very hard to see out of them. I was looking for replacements but they are pretty expensive Does anyone know if any other model’s mirror would work? Like maybe a gs430 or any other model. I tried searching but I couldn’t find anything All I need is the mirror itself
thanks in advance if you can help
Old Dec 18, 2020 | 09:58 PM
BaconLS430's Avatar
BaconLS430
Silly question, but have you tried cleaning them with a quality glass cleaning product? Assuming the answer to that is a yes, have you tried polishing the glass of the mirrors? I would recommend White Diamond Metal Polish (it works great on glass, too) as that could remedy the haze for a much lower price than even used mirrors.
Old Dec 19, 2020 | 05:43 AM
Forbidden's Avatar
Forbidden
Thanks for the suggestions but yes I have. I was told that there is something built in the mirror for the auto dim and that is what went bad. Sorry if I didn’t explain it clearly.
Old Dec 19, 2020 | 02:05 PM
BaconLS430's Avatar
BaconLS430
Hmm. I'm not knowledgeable about the wiring diagram of the mirrors and their electrochromatic function, but from what I understand, all 3 mirrors rely on the sensor in the interior mirror.
More silly questions: Does the interior mirror function as intended? Does turning the auto dim function off have any effect? Have you tried unplugging either door mirror or the interior mirror to see if anything changes?
In the meantime, I'll see if I can dig up a wiring diagram for the mirrors.
Old Dec 21, 2020 | 07:33 AM
Forbidden's Avatar
Forbidden
I press the button on the inside rear view mirror and it does not change anything on the door mirrors. I just wanted to know if other model Lexus mirrors will work as I’ve seen the gs and es models are much cheaper than the LS
airlaird
RC F (2015-present)
118
Aug 4, 2021 08:35 AM
Dstep123
Dec 31, 2015 04:50 PM
Ranger4R
RX - 3rd Gen (2010-2015)
Dec 1, 2014 01:42 AM
dbs600
May 16, 2014 08:52 AM
biginno
Aug 9, 2010 01:46 PM
