OBDLinkMX+ does it work?
Old Dec 15, 2020 | 05:35 PM
Squirrel1's Avatar
Squirrel1
Default OBDLinkMX+ does it work?
Has anyone used one of these? I have been going back and fourth with their customer support. Doesn't work with either of my lexus vehicles from this era. Works on my 98 tahoe though. They have no idea, i honestly don't believe they work with these vehicles
Old Dec 15, 2020 | 07:43 PM
WILLYumD's Avatar
WILLYumD
I have had the OBDLink MX+ scanner for over a year and use it every time I drive to keep an eye on temps and fuel trims.
I have an iPhone and am connecting to the device via Bluetooth.
Are you using their OBDLink app? Did you download the correct Toyota/Lexus features pack for your year?
What exactly is not working?
Old Dec 16, 2020 | 04:29 AM
Squirrel1's Avatar
Squirrel1
i have a note 10+, i am using their app, i have not downloaded anything toyota or lexus specific i dont know anything about that. When i try to connect i get a error saying that the app is connected to the reader but the reader is not connected to the vehicle
Old Dec 16, 2020 | 05:34 AM
BigBoomer's Avatar
BigBoomer
Make certain that the reader is pushed fully into the ODB2 socket.
I had a problem last year with my ODB2 reader and my TechStream cable.
In both cases I simply hadn't pushed the plug in firmly enough. <DOH!>
Old Dec 16, 2020 | 04:20 PM
WILLYumD's Avatar
WILLYumD
I presume the ignition is "ON" when you're trying to connect?
In the app, go to Settings > "Get Enhanced OEM Add-Ons" > "Toyota, Lexus, Scion" > Select your Year > "Get"
Settings > "Preferences" > "Communications":
What do your settings look like?
For reference, mine are attached.
Old Dec 18, 2020 | 09:31 AM
Squirrel1's Avatar
Squirrel1
yes I am in the on position, on my lunch today I'm going to go check out all my settings. Thanks for the help!
Old Dec 19, 2020 | 11:40 AM
Aus430's Avatar
Aus430
I have an obdlink mx+. Android phone.
For my 02 ls430 I could not get the obdlink app to connect, even purchased the lexus toyota pack. I check back every so often in case they fixed it but still won't connect with their app.
After trying *lots* of different apps I eventually found an app that does connect with the ls430 using my obdlink mx+ adaptor
Its called car scanner. The free version works fine. I paid for pro to support the developer cause the app is great and still to this day the only one Ive tried that will actually make a connection with the ls430.
Be aware the first time you connect it will take about 10 minutes (engine running) as it works through lots of setting combos automatically until finally getting to the working combination. (iso14230 from recollection) Once its got the settings worked out it connects in about 10 seconds (engine on or off doesn't matter)
Attached below are screenshots of my connection settings and the app to help find the right one in the play store.
Settings - note it would not connect when toyota or lexus profiles are selected but 'other brand obd' works.
Advanced settings
Hope that helps get your obdlink mx talking with your ls430.
Cheers
SLAMDGS4
CL of Southern California
Feb 6, 2009 05:10 PM
Overclocker
May 29, 2006 11:36 AM
Din
Dec 7, 2002 03:05 AM
