2004 LS430 Timing belt
I did my own timing belt with the aisin (spell?) kit from amazon that does the pump and some pulleys too. I was under $150 I think and took me half a day. There is a good youtube video and the way this engine is so brilliantly designed it only goes back together one way. The Japanese have a word for that but i can't recall it.
OP...
Did Lexus sort out your cold-start noise issue?
Which component was noisy?
Am interested in your post because you are taking your vehicle to Lexus for Timing Belt Service, using OEM parts.and have low mileage, but 16/17 year old timing belt components.
Thanks
Thanks
I did take it to Lexus and they said the noise was coming from the power steering pump. The problem is that it's working fine. The noise goes away after a few minutes. They wanted $1,000.00 to fix it. So I told them to hold off on them both and I will do the timing belt when the power steering pump goes out. I did change the powering steering fluid to a synthetic. There is another guy on here that has had the same noise for 7 years. Who knows how long it will last. I'll probably do them both next year. Not sure if this helps.
Did anyone first remove the serpentine belt to see if the noise abated??
Sorry for the late reply. I've changes the power steering fluid to a full synthetic and everyday the noise is getting quieter. It's not 100% gone but much improved. Still goes away after a few minutes.
TrevorSP
Mar 10, 2023 03:57 AM
