Front door inside handle cable question
Can anybody give me a source for the cable that connects to the inside door handle, that opens the door when you pull the inside handle? Mine snapped, and online searches yield a bewildering array of different results.
Parts catalogues are at https://www.amayama.com/en/genuine-catalogs/lexus/ls430 and https://partsouq.com/en/catalog/genu...us&model=LS430 and several other websites. Use your VIN to search in order to ensure accurate part numbers.
69720B CABLE ASSY, FRONT DOOR LOCK REMOTE CONTROL, LH
69760C CABLE ASSY, FRONT DOOR INSIDE LOCKING LH
There are 2 options of doors, easy-close and normal, and 2 doors, LH and RH, and 2 cables on each door, one for the inside door handle, one for the remote door lock, so that's why you see 8 different options. I believe the one you want is location 69760C - inside locking cable assembly. It is easy to open up your door (I've done it several times) and to replace these cables (never done but looks easy).
dogwisper
Nov 18, 2011 04:04 PM
