Will Work Wheel’s standard A-Disk Clear the LS 430’s front calipers?
Hi Guys, I’m looking at Work M1’s and Work VS XX Step lip, Both wheels have their pros and cons, but I’m definitely leaning towards the M1’s as I’m a sucker for that sandwich/reverse mount. I have figured out these wheel specs from other LS430 owners and the specs on there 3 piece are very close. My question is will A-disks clear the LS 430’s calipers? I’m asking because I want the maximum lip in the fronts lol.
Another info to add is I’m in it to tuck as I am on bags. Clearing calipers are the biggest concern, but clearing the struts are also up there
Work M1
Front: 19x9.5 +19f (71mm lip) Standard A-Disk in question
If they won’t fit, these are also an option:
19x9.5 +20G L-Disk or +24H T-Disk both big caliper setup
Rear: 19x10.5 +17F (96mm lip) or +30 (83mm lip) Both O-disk
Work VS-XX
Front: 19x9.5 +19D 87mm lip A-disk in question
19x9.5 +28F 62mm lip R-disk
+23F 62mm lip T-Disk
Rear: 19x10.5 +26E 100mm lip O-Disk
Work M1 size chart
https://www.workwheelsusa.com/wp-con...ZING-CHART.pdf
Work VS-XX size chart
https://workwheelsusa.com/wp-content...ZING-CHART.pdf
Thanks guys!
Work M1
Work VS-XX
Work M1 size chart
Thanks guys!
Gotcha. I guess I’ll have to settle for less lip since I don’t want to run spacer and pull my fenders too much...
The Work M1’s doesn’t come in an R disk though, only in L and T disks, the closest ones are:
19x9.5 +20G L disk (58mm lip)
19x9.5 +24H T disk (45mm lip)
Of course I want to go maximum lip, but Also don’t want to rub on the knucke (will be shortening it so it’ll be thicker...
I have Work Gnosis on my LS and had to do the R-Disk. I’m not familiar with the T or L option though. I would ask the vendor what’s the difference on them. Ravspec helped me out since I didn’t want spacers with my setup.
RavSpec
Club Lexus Vendor Marketplace
Jun 27, 2012 10:27 AM
