DIY Valve Cover Gaskets
I followed this video when I did mine https://youtu.be/LBLFm0sHic0
I'm still amazed that nobody has done this job and created a tutorial. Shops charge 400-500 for this and either folks have paid it or never recorded it until after they pulled the valve covers. Just weird...
step 1 remove the positive battery wire
step 2 disconnect all ignition coil packs and the coil packs rubber seal first than remove them and keep in order
step 3 un bolt cables to create room to wiggle the covers off passenger 1 person job, driver side 2 person job (for me) that oil dip stick was a b
step 4 remove all 10mm bolts with a i think its called a 1 foot extension and swivel and two 3 inch extenshions and a short 10mm, use pry bar or screw driver to lift it up, change your spark plugs as well if you need to
step 5 clean valve cover and put the seal on and the new spark plug tube seals
step 6 clean the surface on the head where the cover sits on
step 7 fpig the 2 half moons at the back should be 4 spots
step 8 fpig the front corners
step 9 reassemble and move on to the other side same order
Uh I can sorta walk you through it if you want since I have some pictures of when I did mine, it's kinda hard to remember to record everything honestly
Initially thinking you would do both sides in one endeavor suddenly becomes put the tools away and revisit the second side in a couple days...
It's ok we've all been there the second side goes much quicker after the learning curve.
This is why shops charge 400-500.
Once you've tackled this you'll realize removing the old tube seals is by far the most time consuming task. They'll be baked in, hard as a rock, and rather stubborn to remove.
4Litre....Considering the effort required to change the valve cover gaskets, I'd definitely advise using OEM parts for everything needed. Besides following the advice given above, take your time being extra careful in reinstalling the covers, making sure you don't pinch the gasket when reinstalling, Having the gasket adhering properly to the cover before reinstalling should avoid pinching the gasket. Good luck.
