TOM'S Edition LS430
Old Jul 25, 2020 | 08:18 PM
  #61
ARCHIVES's Avatar
ARCHIVES
Got a few part not Tom's related
Old Jul 25, 2020 | 08:26 PM
  #62
ARCHIVES's Avatar
ARCHIVES
Few bit's of Tom's items
Old Jul 27, 2020 | 12:19 PM
  #63
freezingco's Avatar
freezingco
Nice! I actually was looking at those pedals.... but I think I'm almost done with my LS build.
So I mounted up my tom's strut bar and it barely clears over the engine cover... I still need to drive it. I'm wondering if the engine movement will hit the bar or if my engine mounts are shot. This is where on the TOM'S site it says it doesn't fit:
Old Jul 27, 2020 | 04:53 PM
  #64
Lavrishevo's Avatar
Lavrishevo
How about a video of you WOT? I want to see and hear the supercharger.
Old Jul 27, 2020 | 09:14 PM
  #65
freezingco's Avatar
freezingco
Old Jul 27, 2020 | 10:58 PM
  #66
ARCHIVES's Avatar
ARCHIVES
Did you use any spacers to clear fitment?
Old Jul 28, 2020 | 09:46 AM
  #67
freezingco's Avatar
freezingco
I did not. It cleared by a few mm, the closest point is in the center near the Toyota emblem. I added a few sticky felt pads on the underside of the strutbar and still have a small gap.
Old Jul 29, 2020 | 12:01 AM
  #68
ARCHIVES's Avatar
ARCHIVES
auh ok, that's super close
Old Oct 14, 2020 | 11:30 AM
  #69
ARCHIVES's Avatar
ARCHIVES
UPDATE
Been stocking part and just pick up a big brake kit , over kill yes but at a great price.
Old Oct 14, 2020 | 11:34 AM
  #70
ARCHIVES's Avatar
ARCHIVES
Side note ill be state side before the new year build starts soon!!!!!
Old Oct 14, 2020 | 11:54 AM
  #71
Romanova's Avatar
Romanova
Caliper specs? What car did they come off of?
Will a stock master cylinder be able to cope with those calipers?
Old Oct 14, 2020 | 09:08 PM
  #72
ARCHIVES's Avatar
ARCHIVES
Not sure if I have to run spacers I know the original rim was 20x9 but I don't know the offset. And they came off a 03 Toyota Celisor. I talked to brembo right after purchasing them and I should be okay was running a stock master cylinder.
Old Oct 14, 2020 | 09:43 PM
  #73
notmill's Avatar
notmill
How does brake pedal feel with those? They look like the same casting as the older e55 AMG 8 pots. Does it use 4 small pads up front?
I'm starting to piece a bbk together myself and was wondering if I could get bias close enough to factory or maybe biased forwards a little more. Picked up the brembo 6-pots and am planning to transfer the front calipers to the back if they're small enough to maintain a similar brake bias. Do you have a casting or p/n for the calipers by chance?
soon...
Old Oct 15, 2020 | 02:20 AM
  #74
ARCHIVES's Avatar
ARCHIVES
soon...
I work nights shift here in Japan , but soon as I get home I'll post the part numbers.
Old Oct 15, 2020 | 08:13 AM
  #75
Romanova's Avatar
Romanova
I'm curious what vehicle they were on BEFORE they were on the 03. Make sure you weigh them and compare them to the weight of the stock calipers... I'll be curious to see what difference there is, if any. Also what the difference in rotor size is. If the setup is from a JDM-only car, you might want to get fresh rotors and pads before you leave...
