Need help with transmission
Old Feb 8, 2020 | 01:07 PM
LS504's Avatar
LS504
Default Need help with transmission
Does anyone have a diagram or color code for the NEUTRAL SAFETY SWITCH / PARK/NEUTRAL Safety switch connector? Mines deteriorated n I cant figure out the correct pins to match up to the gs400's NSS connector...A picture of the ls430's NSS connector that shows which color wire is assigned to which pin hole would help. Thanks in advanced
These are for the 2001 ls430
This is the 2000 gs400's connector
Old Feb 15, 2020 | 11:03 PM
LS504's Avatar
LS504
bump***
really need a picture of this connector to get things going
Old Feb 19, 2020 | 11:44 AM
LS504's Avatar
LS504
Bump! Anyone??? I found a wiring diagram but I'm still having trouble with locating 3 wires...
Old Feb 19, 2020 | 12:47 PM
rkw77080's Avatar
rkw77080
Old Feb 19, 2020 | 12:56 PM
LS504's Avatar
LS504
Originally Posted by rkw77080
Really appreciate this!
Old Feb 19, 2020 | 02:06 PM
rkw77080's Avatar
rkw77080
You're welcome. The P1 plug for the Park/Neutral Position Switch can be purchased online (Amazon.com). Its part number is 90980−11784.
Old Nov 1, 2021 | 04:42 PM
kaidin's Avatar
kaidin
Default Help, did you ever figure the color code for the nss
Did you ever figure out the color code for the nss
gs300grn
May 18, 2017 04:04 AM
rubeld
Mar 25, 2017 08:36 AM
Beerguy
GS - 1st Gen (1993-1997)
Aug 29, 2013 11:02 AM
