Engine Oil Leakage
Old Jan 18, 2020 | 01:14 PM
  #31
Bocatrip's Avatar
Bocatrip
BMW plastic is hell. It's literally the worst I've encountered and everything from the PCV to electric remote water pumps crack and kill the entire engine. It's so bad that if your PCV hoses crack the engine will start to miss and burn oil and if the owner is stupid it will take out the valve cover seals too. Literally have three BMWs right now with dying plastic that is going to cost the owners a lot to fix
On the subject of plastic...... When I purchased my Jaguar XK Coupe ( I know....they are not reliable cars...agreed)...It had 4,600 miles on it. 6 years later, it now has 11,200 miles. The ENTIRE cooling system with very few exceptions is plastic. Included are a zillion plastic connectors with clamps etc. I've had a coolant smell since purchase and add a few ounces every now and then. Water pumps are notorious for being bad. No where can they find anything leaking and I'm too nervous to have them take anything apart because of collateral damage. My car is not unique as many cars today are plastic everywhere! What happens when these cars start aging? It is what it is....Prices for new cars are in the stratosphere, and materials they use are made of s..t Even with my Lexus, I'm always on top of my Indy to be extra careful (example: changing plugs) as to not break any of the brittle parts when disassembling which is a hard thing to ask anyone. At one time it was just trim pieces that were plastic, now it's common place in the engine compartment. Too bad.
Old Jan 18, 2020 | 01:19 PM
  #32
Bocatrip's Avatar
Bocatrip
Originally Posted by Johnhav430
How about the oil sender, where's that located? When I was under my car, disappointingly, there are lots of places where electrical tape is so brittle it flakes off and breaks. I did my best to wrap up a wire that was simply exposed (maybe from the factory?? it was white), then the group of 4 that it was part of where the insulator broke off. It has a plug, then it goes up somewhere past the alternator....seems so delicate. I felt it should have had a flexible plastic insulator.
p.s. again I feel that along with the so called reliability comes fairly tight tolerances for production, meaning we're all going to have the same issues, a matter of when, with much not mileage but time related...
It's an oil level sender switch. It's located on the driver's side (I believe in the area of the dip stick o ring). Also a total pain to get to. Many owner's replace the dip stick o ring and then find out it's the oil level sender that's leaking. Actually, that's exactly what happened to me. Both can be problematic as the car ages.
Old Jan 18, 2020 | 01:41 PM
  #33
There's the one that runs from radiator to coolant reservoir, kinda dumb...but knock on wood my 2007 has been totally reliable except for ABS failure. I say except because I was able to DIY for < $500 and I needed software and tools. This doesn't exist for the LS, someone paid over $4k I believe on a 2007 for ABS failure
I did notice parts made in Turkey. Me, personally, I prefer parts made in Germany and Austria, but it likely has nothing to do with anything, like wanting Japan made parts. In the 1970's I hear Japan means junk. That's why I say we can't assume Turkey or Hungary is no good.
Although it did not work for Snap On when they removed USA from the tools....
Yep, the 460s have brake by wire style booster units that don't use engine vacuum (extremely similar to Mercedes) that like in any car that has the system will end up with a failure. Just google the issue (Mercedes EBC failure) and it will become very apparent the system is needlessly complicated and exists purely for the sake of hybrid systems and "sophistication" and can quite literally fail without warning.
Least there is a 25 year warranty now.......
Old Jan 18, 2020 | 01:46 PM
  #34
Well if it's any indication there is an entire sub-industry dedicated to making metal versions of many BMW engine plastic parts like the coolant cross overs and water pump manifold/thermostat that all the lines link into.
Newer stuff once the cheap crap ages out will just stop working or require engine out total service. It's just in alignment with the fact most do not keep cars more than 7 years and most warranty periods do not need a part that will last 100 years. Hence plastic oil pans and "spray in" bonded cylinder wall PVD coatings with not enough block material to sleeve requiring a new block entirely for a rebuild, vs a "primitive" iron or sleeved block that can be reused near infinitely.
Old Jan 18, 2020 | 05:50 PM
  #35
aypues's Avatar
aypues
My 04’s engine has finally developed an oil leak at 190k, we think from the valve covers. Debating whether or not to do it but leaning toward doing it, I think it’s about 5 hrs labor for my indy, and they said do spark plugs at same time...although mine were done at 120k, so not technically due until 240k. Is it worth doing early?
Old Jan 18, 2020 | 08:46 PM
  #36
Yes, its in the way when doing the covers
Old Jan 18, 2020 | 11:31 PM
  #37
ahde's Avatar
ahde
I am afraid many replies in this thread have digressed to other issues or provide answers I already know ( like have the valve cover gasket, cam seal, etc. replaced now) though I again thank them for their contributions. I have started another thread which pinpoints to what I don't know and would like to seek advice. That is, has anyone used ATP Re-sealer or similar substance to successfully stop engine oil leak in his LS430 temporarily while awaiting for a more permanent fix?
Old Jan 19, 2020 | 08:03 AM
  #38
swfla's Avatar
swfla
You have received several answers about ATP sealer. They all say it's temporary and SOMETIMES works (no guarantees) by making old dry gaskets swell and/or using particulates in suspension. Both will cause engine damage if used long enough. Several commented that waiting to change your timing belt is a bad idea ( as it's way past time (just as bad as miles). This caused me to change my opinion about waiting. Hope this recap helps you to make a decision.
nerijus
Mar 31, 2020 08:00 PM
Hiroshi12
26
Dec 23, 2016 02:59 PM
Aron9000
Mar 24, 2014 02:36 AM
golfdawg
13
May 18, 2012 07:24 AM
MNSC3
Nov 3, 2011 09:56 PM
