Possible transmission issue?
I have a 2004 ls430 and I can't tell if the clutch is slipping or what. The issue that I am having is when I'm in 5th or 6th gear. At around 2.5k-3.5k rpms ill give it around 30-40% throttle and the rpms will climb up normally but then suddenly they fall back down 500 rpm. Does anybody have an idea on what's going on? I think I might have felt it slightly in 4th gear earlier today. After the dip in rpm it will climb back up and it won't do it again until I shift into 6th. If I'm at 4k rpm+ and give it 30-40% the rpms will not dip.
Thank you for the replies guys. I will try and take a video of it and post it on here. I've noticed that it's been happening during the winter months. I don't remember or I don't think it was doing it this summer. It's been a mild winter here in Missouri, the time's I've noticed it the temp has been around 45-50F. My Mileage is at 133k, the last transmission service was at 71k, it states it was flushed at the Lexus dealership in Illinois. I'm not sure if you want me to post the entire service history but here you go. ( Sorry if it's a long list).
REPAIR# 0114859
REPORTED BY: Lexus of Naperville
SERVICE: BRAKE CONCERN
DESCRIPTION: BRAKE CONCERN ~|~CUSTOMER STATES THE STEERING SHAKES WHEN APPLYING BRAKES, MORE AT HIGHWAYS SPEEDS , CHECK AND ADVISE. JUST HAD BRAKES REPLACED HERE ON 4/26/16 ~|~FRONT ROTORS ARE WARPED ~|~RESURFACED FRONT ROTORS RETEST DROVE CAR AND VIBRATION IS NO LONGER PRESENT. INTERNAL PER MICHAEL R. IF VIBRATION RETURNS WILL NEED TO REPLACE FRONT ROTORS.SHOW LESS
SERVICE: MULTI-POINT INSPECT.
DESCRIPTION: MULTI-POINT INSPECT. ~|~CUSTOMER REQUESTS COURTESY MULTI-POINT VEHICLE INSPECTION. ~|~ ~|~COMPLETED COURTESY MULTI-POINT VEHICLE INSPECTION.
REPAIR# 0103578
SERVICE: COOLING SYSTEM
DESCRIPTION: COOLING SYSTEM ~|~REC REPLACING WATER PUMP WITH TIMING BELT---NO LEAK PRESENT AT THIS TIME ~|~REPLACED WATER PUMP WITH TIMING BELT--ADDITIONAL 1.0 LABOR
SERVICE: ENGINE CONCERN
DESCRIPTION: ENGINE CONCERN ~|~CUSTOMER STATES TO REPLACE TIMING BELT WITH NEW DRIVE BELT ~|~REPLACED TIMING BELT AND DRIVE BELTENGINE CONCERN ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONE
SERVICE: ENGINE OIL
DESCRIPTION: ENGINE OIL ~|~CUSTOMER REQUESTS OIL & FILTER REPLACEMENT. ~|~5Q/PSI ~|~COMPLETED OIL & FILTER REPLACEMENT.
SERVICE: FRONT BRAKE JOB
DESCRIPTION: FRONT BRAKE JOB ~|~CUSTOMER REQUESTS FRONT BRAKE PAD REPLACEMENT AND RESURFACE FRONT BRAKE ROTORS. ~|~REPLACED PADS/RESURFACE ROTORS-- ~|~COMPLETED FRONT BRAKE LINING REPLACEMENT AND RESURFACED FRONT ROTORS.
DESCRIPTION: MULTI-POINT INSPECT. ~|~CUSTOMER DECLINES COURTESY MULTI-POINT VEHILCE INSPECTION FOR THIS VISIT. ~|~ ~|~COMPLETED COURTESY MULTI-POINT VEHICLE INSPECTION.
SERVICE: QUICK SERVICE
DESCRIPTION: QUICK SERVICE ~|~P0031--BANK 1 SENSOR 1 CODE---NEED TO REPLACE BAD SENSOR ~|~ ~|~REPLACED SENSOR CLEARED CODES--TEST DRIVE---NO CODES PRESENT VEHICLE CHECKED OK AT THIS TIME
SERVICE: REAR BRAKE JOB
DESCRIPTION: REAR BRAKE JOB ~|~CUSTOMER REQUESTS REAR BRAKE PAD REPLACEMENT AND RESURFACE REAR ROTORS/DRUMS ~|~REPLACE REAR PADS/RESURFACE ROTORS ~|~COMPLETED REAR BRAKE PAD REPLACEMENT AND RESURFACED REAR ROTORS/DRUMS.
REPAIR# 0103463
DESCRIPTION: BRAKE CONCERN ~|~CUSTOMER STATES THAT WHEN BRAKING SAYS HE GETS A SHIMMY IN THE FRONT END, USUALLY WHEN DRIVING ON HIGHWAY AND THEN BRAKING ~|~FRONT AND REAR PADS AT 1MM --CHECKED ALL CALIPERS--OK---REC FRONT-REAR BRAKE JOB
SERVICE: CHECK ENGINE LIGHT
DESCRIPTION: CHECK ENGINE LIGHT ~|~ENGINE LIGHT CONCERN - NEEDS DIAGNOSIS. CHECK ENGINE, VSC, AND TRAC OFF LIGHTS ARE ALL ON. VEHICLE IS SHAKING AS WELL. ~|~CLEARED CODES FOR NOW WAITING FOR CUSTOMER APPROVAL
DESCRIPTION: COOLING SYSTEM ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONE
DESCRIPTION: ENGINE CONCERN ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONEENGINE CONCERN ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONE
DESCRIPTION: FRONT BRAKE JOB ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONE
DESCRIPTION: QUICK SERVICE ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONE
DESCRIPTION: REAR BRAKE JOB ~|~ ~|~,CUSTOMER DECLINED SERVICE -RECOMMENDED NOT DONE
REPAIR# 0285578
SERVICE: PERFORM 5K MILE MAINTENANCE INCL. OIL CHANGE, TIRE ROTATION (EXCEPT MODELS WITH
DESCRIPTION: PERFORM 5K MILE MAINTENANCE INCL. OIL CHANGE, TIRE ROTATION (EXCEPT MODELS WITH ~|~PERFORM 5K MILE MAINTENANCE INCL. OIL CHANGE, TIRE ROTATION (EXCEPT MODELS WITH DIFFERENT SIZE FRONT AND REAR TIRES), SET TIRE PRESSURE, TOP OFF FLUIDS, AND MULTI-POINT VEHICLE INSPECTION ~|~ ~|~85563 5K MILE MAINTENANCE SERVICE. 100 PERFORMED OIL CHANGE, TIRE ROTATION, SET TIRE PSI, TOPPED OFF FLUIDS, AND PERFORMED MULTI-POINT VEH INSPECTION. FRONT BRAKE PADS: 6MM. REAR BRAKE PADS: 5MM. FRONT TIRES: 5/32"". REAR TIRES: 4-5/32"". TIMING BELT/SERPSHOW LESSSHOW LESS
REPAIR# 0274819
SERVICE: REPLACE BRAKE ACTUATOR
DESCRIPTION: REPLACE BRAKE ACTUATOR ~|~CUST STATES BRAKE PEDAL SINKS WHEN SITTING AT IDLE FOR A COUPLE TO A FEW MINUTES THEN VEH WILL SLOWLY MOVE FORWARD WHILE BRAKE PEDAL IS ALREADY PUSHED TO THE FLOOR ~|~ ~|~80092 BRAKE ACTUATOR FAILURE / WARPED BRAKE ROTORS. 450 TEST DROVE VEH AND VERIFIED SINKING BRAKE PEDAL. ALSO VERIFIED A BRAKE PULSATION. BLED EACH INDIVIDUAL BRAKE LINE TO EACH CALIPER AND BRAKE PEDAL WAS STILL SINKING. BLOCKED BRAKE FLUID FLOW BETWEEN CSHOW LESS
REPAIR# 0273046
DESCRIPTION: PERFORM 5K MILE MAINTENANCE INCL. OIL CHANGE, TIRE ROTATION (EXCEPT MODELS WITH ~|~PERFORM 5K MILE MAINTENANCE INCL. OIL CHANGE, TIRE ROTATION (EXCEPT MODELS WITH DIFFERENT SIZE FRONT AND REAR TIRES), SET TIRE PRESSURE, TOP OFF FLUIDS, AN...READ MORE
SERVICE: PERFORM WHEEL ALIGNMENT
DESCRIPTION:
SERVICE: REPLACE BATTERY
DESCRIPTION: REPLACE BATTERY ~|~BATTERY FAILED LOAD TEST ~|~ ~|~78976 BATTERY FAILED LOAD TEST. 50 REPLACED BATTERY.
SERVICE: REPLACE FRONT STRUTS
DESCRIPTION: REPLACE FRONT STRUTS ~|~FRONT STRUTS ARE LEAKING ~|~ ~|~78978 FRONT STRUTS ARE LEAKING. 550 REPLACED FRONT STRUTS AND PERFORMED WHEEL ALIGNMENT.
SERVICE: REPLACE WIPER INSERTS
DESCRIPTION: REPLACE WIPER INSERTS ~|~WIPERS ARE STREAKY/WORN ~|~ ~|~78976 WIPERS ARE STREAKY/WORN. 20 REPLACED WIPER INSERTS.
REPAIR# 0255911
SERVICE: 48 MONTHS OR 60,000 MILES OIL CHANGED,TIRES ROTATED,ENGINE AIR FILTER REPLACED,C
DESCRIPTION: 48 MONTHS OR 60,000 MILES OIL CHANGED,TIRES ROTATED,ENGINE AIR FILTER REPLACED,C ~|~48 MONTHS OR 60,000 MILES OIL CHANGED,TIRES ROTATED,ENGINE AIR FILTER REPLACED,COOLANT AND BRAKE FLUIDS FLUSHED,TRANS FLUID REPLACED,DIFFERENTIAL FLUIDS REPLACED,ALL INSPECTIONS PERFORMED. ~|~ ~|~71804 400 PERFROMED 60K SERVICE.TIRES AT 6/32 FRT AND REAR,BRAKES AT 8MM FRT AND 6MM REAR, TEST DROVE VEHICLE AFTER REPAIRSSHOW LESS
SERVICE: DEFAULT
DESCRIPTION: DEFAULT ~|~CUSTOMER STATES CHECK ENGIN, VSC AND TRAC LIGHTS ON DASH ~|~ ~|~71804 P0441,P0442,P0455 300 REPLACED CHARCOAL CANISTER
SERVICE: PDC
DESCRIPTION: PDC ~|~CUSTOMER STATES PARK DISTANCE SENSOR FOR FRONT OF VEHICLE KEEPS GOING OFF INTERMITENTLY, CHECK AND ADVISE ON REPAIR ~|~ ~|~71804 50 FOUND FRT RIGHT CENTER PARK ASSIST SENSOR DAMAGED.CUSTOMER DECLINED REPAIRS
SERVICE: REPLACE AIR CONDITIONING FILTER
DESCRIPTION: REPLACE AIR CONDITIONING FILTER ~|~REPALCE AIR CABIN FILTER AS PART OF 60K SERVICE ~|~ ~|~71804 30 REPLACED CABIN AIR FILTER
REPAIR# 0213787
SERVICE: 8 MONTH/10,000 MILE SERVICE CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK B
DESCRIPTION: 8 MONTH/10,000 MILE SERVICE CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK B ~|~8 MONTH/10,000 MILE SERVICE CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRAKES, PERFORM INSPECTION AND TOP OFF FLUIDS AS NEEDED ~|~ ~|~55482 100 REPL...READ MORE
REPAIR# 0196813
SERVICE: PERFORMED OIL CHNAGE
DESCRIPTION: PERFORMED OIL CHNAGE ~|~5000 MILE-QUICK OIL SERVICE ~|~ ~|~50101 PERFORMED 5Q SERVICE.
REPAIR# 0183723
SERVICE: 5000 MILE-QUICK OIL SERVICE
DESCRIPTION: 5000 MILE-QUICK OIL SERVICE ~|~5000 MILE-QUICK OIL SERVICE ~|~. ~|~45517 50 REPLACE ENG OIL & FILTER,TOP OFF FLUIDS & RESET OIL LIFE MONITORS. **** RECOMMEND 45K SERVICE. *****
SERVICE: MOUNT AND BALANCE 4 TIRES
DESCRIPTION: MOUNT AND BALANCE 4 TIRES ~|~MOUNT AND BALANCE 4 TIRES ~|~ ~|~45517 200 MOUNT & BALANCE 4 NEW TIRES WITH NEW VALVE STEMS. ALSO NEC TO CLEAN RIMS OF CORROSION & INSTALL BEAD SEALER TO PREVENT LEAKS. REINITIALIZE TIRE PRESSURE WARNING...READ MORE
SERVICE: PERFORM 4 WHEEL ALIGNMENT
DESCRIPTION: PERFORM 4 WHEEL ALIGNMENT ~|~PERFORM 4 WHEEL ALIGNMENT ~|~ ~|~45517 150 4 WHEEL ALIGNMENT & ROAD TEST COMPLETED.
SERVICE: RELINE FRONT BRAKES, RESURFACE FRONT ROTORS, CLEAN AND ADJUST FRONT CALIPERS
DESCRIPTION: RELINE FRONT BRAKES, RESURFACE FRONT ROTORS, CLEAN AND ADJUST FRONT CALIPERS ~|~RELINE FRONT BRAKES, RESURFACE FRONT ROTORS, CLEAN AND ADJUST FRONT CALIPERS ~|~ ~|~45517 250 REPLACE FRT BRK PADS,RESURFACE ROTORS,CLEAN & ADJUST FRT CALIP...READ MORE
SERVICE: REPLACE CABIN AIR FILTER
DESCRIPTION: REPLACE CABIN AIR FILTER ~|~REPLACE CABIN AIR FILTER ~|~ ~|~45517 030 REPLACE CABIN AIR FILTER-DIRTY/MESSAGE ON DASH.
SERVICE: REPLACE REAR BRAKE PADS, RESURFACE REAR ROTORS, CLEAN AND ADJUST REAR CALIPERS
DESCRIPTION: REPLACE REAR BRAKE PADS, RESURFACE REAR ROTORS, CLEAN AND ADJUST REAR CALIPERS ~|~REPLACE REAR BRAKE PADS, RESURFACE REAR ROTORS, CLEAN AND ADJUST REAR CALIPERS ~|~ ~|~45517 250 REPLACE REAR BRAKE PADS,RESURFACE ROTORS,CLEAN & ADJUST RE...READ MORE
SERVICE: SEE NOTES
DESCRIPTION: SEE NOTES ~|~CUSTOMER REQUESTS BRAKES AND TIRES INSPECTED ~|~ ~|~45517 SEE LINES ""E-G-H"".
SERVICE: TECH INSPECTED AND REPLACED INTERNALLY SHORTED SENSOR
DESCRIPTION: TECH INSPECTED AND REPLACED INTERNALLY SHORTED SENSOR ~|~CUSTOMER STATES THAT THE INDICATOR ON DASH FOR AFS KEEPS COMING ON -WHILE DRIVING ~|~ ~|~45517 050 REPLACE REAR AFS (HEIGHT) SENSOR-BINDING/STUCK ACTUATOR ARM.
REPAIR# 0163706
SERVICE: REMOVED SEIZED PLATE BOLT (REAR)
DESCRIPTION: REMOVED SEIZED PLATE BOLT (REAR) ~|~CUSTOMER IS REQUESTING BROKEN ANTENNA BE REPLACED ~|~ ~|~40189 LEXUS LINK ANTENNA BROKEN, BOLTS SEIZED IN REAR LICENSE PLATE 30 EXTRACT ONE SEIZED BOLT, DRILL OUT AND TAP OTHER BOLT. QUOTED PRICE ON REPLA...READ MORE
SERVICE: REPLACE ENGINE OIL & OIL FILTER, ROTATE TIRES, MEASURE TIRE TREAD DEPTH, ADJUST
DESCRIPTION: REPLACE ENGINE OIL & OIL FILTER, ROTATE TIRES, MEASURE TIRE TREAD DEPTH, ADJUST ~|~REPLACE ENGINE OIL & OIL FILTER, ROTATE TIRES, MEASURE TIRE TREAD DEPTH, ADJUST TIRE PRESSURE, CHECK BRAKE PADS AND ROTORS, CHECK FLUIDS AND ADJUST, ...READ MORE
REPAIR# 0143485
SERVICE: 52 MONTHS OR 65,000 MILES CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRA
DESCRIPTION: 52 MONTHS OR 65,000 MILES CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRA ~|~52 MONTHS OR 65,000 MILES CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRAKES, PERFORM INSPECTION AND TOP OFF FLUIDS AS NEEDED ~|~ ~|~34764 65K 100 6/...READ MORE
REPAIR# 0129463
SERVICE: FRONT BUMPER ASSEMBLY
DESCRIPTION: FRONT BUMPER ASSEMBLY ~|~CUSTOMER STATES THAT THE PARK ASIST SENSORS GOES OFF IRRATICALLY ~|~RIGHTANDLEFTCENTERPARKINGASSI STSENSORSERRONEOUSLYENGAGE/SH ORTED/REPLACEDBOTHRIGHTANDLEF TCENTERSENSORS ~|~30775 520041-T187-T217 130 RIGHT & ...READ MORE
SERVICE: MIRROR SWITCH WAS SET TO CENTER POSITION(DISABLES FEATURE)
DESCRIPTION: MIRROR SWITCH WAS SET TO CENTER POSITION(DISABLES FEATURE) ~|~CUSTOMER STATES THAT THE MIRRORS DO NOT FOLD IN ~|~ ~|~30775 MIRROR SWITCH WAS NOT SET TO AUTO POSITION(CENTER POSITION ON SWITCH).
REPAIR# 0124205
SERVICE: 24 MONTHS OR 30,000 MILES OIL CHANGED,TIRES ROTATED,ENGINE AIR FILTER REPLACED,C
DESCRIPTION: 24 MONTHS OR 30,000 MILES OIL CHANGED,TIRES ROTATED,ENGINE AIR FILTER REPLACED,C ~|~24 MONTHS OR 30,000 MILES OIL CHANGED,TIRES ROTATED,ENGINE AIR FILTER REPLACED,COOLANT AND BRAKE FLUIDS FLUSHED,TRANS FLUID REPLACED,DIFFERENTIAL FLUIDS REP...READ MORE
SERVICE: REPAIRED PUNCTUR IN RR TIRE NOW R/F
DESCRIPTION: REPAIRED PUNCTUR IN RR TIRE NOW R/F ~|~RIGHT REAR TIRES HAS A LEAK ~|~ ~|~29036 REPAIRED PUNCTURED R/R TIRE,NOW ON R/F 50
REPAIR# 0108444
SERVICE: 20 MONTHS OR 25,000 MILES CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRA
DESCRIPTION: 20 MONTHS OR 25,000 MILES CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRA ~|~20 MONTHS OR 25,000 MILES CHANGE OIL, REPLACE FILTER, ROTATE TIRES AND CHECK BRAKES, PERFORM INSPECTION AND TOP OFF FLUIDS AS NEEDED ~|~ ~|~24727 PERFORMED ...READ MORE
SERVICE: GUEST FORGOT COUPON AT HOME/APPLIED $10 DISCOUNT
DESCRIPTION: GUEST FORGOT COUPON AT HOME/APPLIED $10 DISCOUNT ~|~PROVIDE COUPON
REPAIR# 0090945
SERVICE: 12 MONTHS OR 15,000 MILES
DESCRIPTION: 12 MONTHS OR 15,000 MILES ~|~12 MONTHS OR 15,000 MILES ~|~ ~|~19074 PERFORM 15K, CHANGE OIL & FILTER, ROTATE TIRES, INSPECT BRAKES, REPLACING ENGINE AIR FILTER & WIPERS, MULTI-POINT INSPECTION & REPLENISH FLU
DESCRIPTION:
REPAIR# 0069860
DESCRIPTION: 8 MONTH/10,000 MILE SERVICE ~|~8 MONTH/10,000 MILE SERVICE ~|~ ~|~REPLACE ENGINE OIL AND FILTER ROTATE TIRES INSPECT AIR FILTER INSPECT FRONT AND REAR BRAKES INSPECT STEERING LINKAGE INSPECT DRIVE SHAFT BOOTS RE-TORQUE FLANGE BOLTS INSPECT ...READ MORE
REPAIR# 0043561
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: 5,000 MILE SERVICE ~|~5000 MILE SERVICE (DOFU?-12MON) ~|~5K ~|~5248 .6 .6
REPAIR# 0032269
SERVICE: 1,000 MILE SERVICE
DESCRIPTION: 1,000 MILE SERVICE ~|~1000 MILE SERVICE ~|~1K
SERVICE: CAR NEEDS TO GO TO BODYSHOP FOR REPAIR
DESCRIPTION: CAR NEEDS TO GO TO BODYSHOP FOR REPAIR ~|~CUSTOMER STATES RIGHT FRT DOOR MOLDING LOOSE
REPAIR# 0027650
SERVICE: 1 SET LIC PLATE FRAMES
DESCRIPTION: 1 SET LIC PLATE FRAMES ~|~1 SET LIC PLATE FRAMES
REPAIR# 0026890
SERVICE: WHEEL SWAP
DESCRIPTION: WHEEL SWAP ~|~SWAP 5 TIRES/WHEELS WITH SOLD UNIT # 5386 ~|~ ~|~TECH SWAPPED 5 TIRES/WHEELS WITH SOLD STOCK# 5386
REPAIR# 0026819
SERVICE: WHEEL SWAP
DESCRIPTION: WHEEL SWAP ~|~SWAP WHEELS/CHROMES WITH SOLD UNIT 3 5436 ~|~ ~|~SWAP WHEELS WITH SOLD UNIT # 5436
REPAIR# 0024853
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PSI INSPECTION COMPLETE
SERVICE: ST/WHL OFF-CENTER (TIE RODS)
DESCRIPTION: ST/WHL OFF-CENTER (TIE RODS) ~|~STEERING WHEEL OFF CENTER ~|~STEERING WHEEL OFF CENTER TO LEFT//STRAIGHTEN STEERING WHEEL / ADJUST
119880 MILES
DATE: 09/26/2016REPAIR# 0114859
115741 MILES
DATE: 04/26/2016REPAIR# 0103578
SERVICE: ENGINE OIL
155663 MILES
DATE: 04/23/2016REPAIR# 0103463
85563 MILES
DATE: 08/19/2013REPAIR# 0285578
80092 MILES
DATE: 04/04/2013REPAIR# 0274819
78978 MILES
DATE: 03/09/2013REPAIR# 0273046
DESCRIPTION:
71804 MILES
DATE: 07/28/2012REPAIR# 0255911
SERVICE: DEFAULT
SERVICE: PDC
55482 MILES
DATE: 02/15/2011REPAIR# 0213787
50101 MILES
DATE: 07/22/2010REPAIR# 0196813
45519 MILES
DATE: 02/16/2010REPAIR# 0183723
SERVICE: SEE NOTES
40190 MILES
DATE: 06/19/2009REPAIR# 0163706
34764 MILES
DATE: 10/17/2008REPAIR# 0143485
30775 MILES
DATE: 05/10/2008REPAIR# 0129463
29036 MILES
DATE: 03/05/2008REPAIR# 0124205
24727 MILES
DATE: 09/05/2007REPAIR# 0108444
19074 MILES
DATE: 01/27/2007REPAIR# 0090945
DESCRIPTION:
11538 MILES
DATE: 04/22/2006REPAIR# 0069860
5248 MILES
DATE: 03/31/2005REPAIR# 0043561
2916 MILES
DATE: 09/09/2004REPAIR# 0032269
18 MILES
DATE: 06/17/2004REPAIR# 0027650
18 MILES
DATE: 06/04/2004REPAIR# 0026890
SERVICE: WHEEL SWAP
14 MILES
DATE: 06/03/2004REPAIR# 0026819
SERVICE: WHEEL SWAP
13 MILES
DATE: 04/29/2004REPAIR# 0024853
Sorry to post this much later than intended. Work has been extremely busy
. I finally made a short clip on what's going on. The outside temp when this was taken was around 30f. You can see the fluctuation in rpm while accelerating in 6th gear. This does happen in 5th, it is more pronounced when driving 40-60 mph rather than 60-80mph. It's still noticable at those speeds in 5th but not as much. 1-4th does not do this. Any ideas?
Just saw this. To me it looks normal, but I have a question. When I am driving along at highway speeds, the RPM remains steady until I back off the accelerator and hit it again (even lightly). It temporarily unlocks the torque converter for a bump in RPM and then settles back down. Is this what you're seeing?
My 01 has 148,000 miles. I find sometimes that during the first warm up drive, when accelerating to 50mph+ the final shift into 5th seems to be delayed or (another way of saying) it hesitates for that final shift. For the most part, since the car is so quiet, I really never notice if and when the car is actually shifting. From 4th to 5th is only detectable by looking at the tach.
