2001 LS430 Armrest Lid Cover Replacement
Hi,
Does anyone here happen to have the DIY somewhere so I that can follow the step to remove the armrest lid cover ? I have bought the new cover but not sure how to remove it for the new cover.
Thanks,
Andy
Thanks,
Andy
Fourth pic are the screws I removed under the console to remove the arm rest.
There are 12 screws to remove. 8 small and 4 larger screws at the bottom of the arm rest. Once these are removed the cover will come off with a little wiggling to free up the air vents.
Once removed I pulled out the staples holding the old skin on the arm rest.
The new skin was templated perfectly. There were marks on the back for where to cut. I only needed to cut out the hole for the rear air vents. I tried to use my pneumatic stapler to attach the new skin but it was too strong. Tried an arrow stapler but it was too weak. I ended up using a hot glue gun and some large paper clips to hold while the glue dried.
The work took 30 minutes, add 60 minutes for the glue to dry and to remount and it's a 90 minute project. Looks great and the color really matches. I am planning to "refinish" the seats next week.
Here is one guy's technique to re-cover:
Here is the best tips I can give you:
1) purchase the foam pad to place inside the new cover for increased comfort
2) have a professional staple it to the hard Lexus plastic.
installation/removal is super easy. Try not to break the two connectors from inside. Good luck
It is much better to use leather glue instead of staple.
