replaced battery
Old Dec 4, 2019 | 06:40 AM
khowell68's Avatar
khowell68
Default replaced battery
replaced the battery in my lexus ls 430 and the strangest thing is happening all the inside the care are on and the parking lights and brake lights are on what could be my issue and after putting the key in to start it will not turn over.
Old Dec 4, 2019 | 08:53 AM
Johnhav430's Avatar
Johnhav430
On my car I noticed the terminal clamps are wonky. Meaning tightening the nut on the negative did not clamp down on the post any better (as if continuing to tighten distorted the clamp), and it was still pretty loose--the sweet spot was to back off. If it were as simple as replacing them I would, but it would seem to be a slippery path attempting that. So I just tightened as best I could, meaning a clear example where tightening more and more was making things worse.
Old Dec 4, 2019 | 11:12 AM
Paulanth's Avatar
Paulanth
Default Replaced battery
I am no expert here; but,
1. Try disconnecting battery
for 20 to 30 mins. & then
reattach cables.
2. If cable clamps are loose,
replace the clamps, or wrap
battery terminal(s) with a thin sheet of copper(to fill the spaces), or a auto parts store may sell copper terminal caps.
3. Good luck.
intempo
Oct 5, 2017 05:48 AM
tradosauru
Jun 20, 2016 03:18 PM
stevek1
Jul 31, 2013 08:51 AM
SixTenWRV
Hybrid Technology
Oct 8, 2010 10:26 AM
2jzism
Jun 2, 2009 09:47 AM
