Radiator replacement: Contemplating using denso 221-4100 with towing. Performed ok?
I am contemplating using Denso 221-4100 With Towing Radiator. For those who have used this radiator, have they held up? Or are there advantages to using the non-towing model Denso 221-3170, since my car did not come with the towing package? Or another radiator?
Also, may replace rubber footings and top brackets, since there is quite a bit of play. Or could just bend the top brackets? But 20 year old rubber becomes pretty stiff. Planning to get OEM hoses, since have heard that fit is better.
Also, should I replace the rubber transmission fluid hoses that connect to radiator, and does anyone have part numbers?
Thanks.
Thanks.
Willauflex
08-31-19 08:24 AM
