headlight Low beam stop working sometimes, is it the bulb or the ballast?
When it does light up, it could fail to light up again if I switch the light off and turn it on again.
I replaced both low beam bulbs a few months ago for this problem, it worked for a while then problem came back again.
I read somewhere that those HID bulbs usually don't go bad, they dime over time to a point that needs replacement.
Also the fact the bulb works sometimes suggest the ballast is bad and not able to ignite the bulb properly.
Anyone can confirm whether this symptom shows the ballast is bad or is it the bulb gone bad again?
Also, if it's the ballast, is there a guide on how to replace it?
Replacing ballast seems easy if I take out the whole headlight assembly, and lucky me has a 2002, which doesn't need to take off bumper to do that.
Found a video here:
https://www.clublexus.com/forums/ls-...l#post10125982
2004 and later would need to loosen the bumper to get access to another bolt:
https://www.clublexus.com/forums/ls-...l#post10237345
Still could use some suggestion on whether my ballast is bad though.
