Exhaust Y pipe options?
Old Jun 25, 2019 | 11:26 AM
TominPT's Avatar
TominPT
Yodaone- per the Magnaflow website : "As a market leader, MagnaFlow proudly manufactures products in the USA from our Oceanside, California facility . . . " Elsewhere they mention they use 409 grade SS for at least some of their products.
Old May 19, 2023 | 08:44 AM
getitright's Avatar
getitright
10th Gear
No surprise, the OEM mid Y-pipe is made of strong magnetic material, if its SS at all should be T409.
Old Jan 31, 2026 | 05:48 AM
victorjohn's Avatar
victorjohn
Default Y-Pipe Replacement - Magnaflow #24169
Hi All,
I’m at my wits end with my 2006 Lexus LS430. Over the course of last Summer I replaced two O2 sensors and then recently the catalytic converter. I kept getting a VSC error code and it evidently led to a leaky Y-pipe. Apparently they don’t make stock units anymore so my shop put on a Magnaflow Y-pipe. The error message is gone now, but the car sounds like a souped up Dodge Charger or Mustang Cobra. I just want my whisper quiet Lexus back. Any suggestions?
Old Jan 31, 2026 | 09:47 AM
BigBoomer's Avatar
BigBoomer
The Y pipe has no noise reduction in it except for the secondary CAT.
If the secondary CAT wasn't replaced it will get considerably louder.
OEM has primary and secondary CATs, then Resonators and finally mufflers.
All of these reduce the exhaust volume, so any change will affect it.
On mine the exhaust tech re-used the OEM secondary CAT but made a new Y-pipe section.
Old Feb 2, 2026 | 08:35 AM
weldthedif's Avatar
weldthedif
i used a cheap rockauto one and its been 5 years and no complaints. I did have to modify it a tiny bit to get it to fit
Old Feb 2, 2026 | 03:34 PM
Johnhav430's Avatar
Johnhav430
Originally Posted by heartygrn
I installed my Davico Y pipe this weekend. Fits perfectly, no welding or bending, just used hand tools and a dremel for cutting bolts when needed. If you get it I strongly recommend getting the OEM front gaskets as they have a much smaller diameter than the ones that come with the pipe, and I can't imagine using those would work. Part number is 90917-A6003 and you'll need two. Also, there is a silver colored gasket that goes in the center pipe where the Y pipe connects, 17451-50020. My guess is anyone with fitment issues did not replace this gasket and therefore did not get a good seal. Finally, I used the 4 OEM flanged bolts 90105-10558 and nuts 90179-10128, and clamp 17452-50020 and clamp bolt 90119-08931. I'd recommend the nuts and bolts but any similar band style clamp would probably do. Hope this helps someone out.
I ended up taking down the entire exhaust and found some holes in the muffler tops. I patched them with muffler sealer and it's very quiet for now. The mufflers don't seem to do much, most of my noise was coming from the Y pipe, but if anyone has some good stock mufflers on hand I'd be interested.
I went this route almost a year ago. Literally Super Bowl weekend 2024, and our team did win, I was feeling that I wanted to be done the easy way, and Midas said they could do it for $230. I know the part would be cheap and I'd be back in 18 mos. But, they called and said dunno what we were looking at but there is NO part available for your vehicle, sorry. So ended up getting the Davico and having a shop install. I wanna say now it was $500 all in. $350 for shipping and tax on the part, and another $150 parts and labor (the Toyota gaskets).
GhostTM
Performance
Nov 21, 2012 04:27 PM
GenuineKid
IS F (2008-2014)
15
Jun 12, 2011 02:53 PM
TeeLex
Performance
35
Aug 20, 2008 10:36 AM
Spyder187
Jun 25, 2005 12:56 PM
CmputerWiz
Jun 29, 2001 12:15 PM
