01 Lexus LS 430 Horn not working
Hi guys I have a base model 01 LS430 and the horn does not work. Where is the fuse box located and what number is it? Any diagrams would be greatly appreciated. Thanks in advance for any help provided.
Will your engine start? Do your headlights work? If not, check out the link below for more information...
https://www.clublexus.com/forums/ls-...n-t-start.html
On a side note, a couple months ago I was viewing code on a check engine light with an OBD2 reader, cleared the code and then had issues with the VSC being disabled. I read about jumping it with a paperclip on this forum to get the VSC to come back on and it worked. Shortly after that the car had a one time electrical anomaly where all the windows, sunroof etc all opened all the way down on their own. I put everything back up and never had that issue since.
I'm wondering if jumping the terminal for the VSC could have shorted something out causing the horn not to work? The car is currently at my independent mechanic and he's looking for the issue, but since he's not a Lexus technician advised me to do some research on my own to cut down on Labour costs as troubleshooting this could take hours and be quite costly.
Appreciate all the help you or anyone else can provide with this issue.
Here is how I remedied my intermittant horn issue;
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/829125-intermittent-horn.html
Thanks again for your help. This is a great community.
Thanks for the input. Thankfully in my case it wasn't a wiring issue and just a couple blown out fuses.
Jezo
CT 200h Model (2011-2017)
04-17-19 09:39 AM
wopdud
01-13-18 06:52 AM
