telescopic stearing and upand down not fuctioning
Second, check the 20A fuse in the driver-side fuse box called "TI&TE" to make sure it's not blown. Your fuse is not blown since the telescopic function operates manually.
If these are not the culprits, then check out the following links:
Discussion on "Telescopic":
https://www.clublexus.com/forums/ls-...-write-up.html
Discussion on "Tilt":
https://www.clublexus.com/forums/ls-...placement.html
Your description of the problem suggests that the automated functions are disabled (you can enable these function with TechStream); and your "Tilt" motor (or its wiring) is bad.
Last edited by rkw77080; Jan 13, 2018 at 07:34 AM. Reason: Added clarifications in RED
Do you care if it's disabled? My telescope was weak, so I got the wheel where I wanted, and pulled the fuse. I would rather have the tilt up after shutting off disabled, but I don't have that techstream....the 2nd way, the tilt/telescope would work manually...I don't want it doing it every time because it could get stuck out of position, and I just don't feel it's worth fixing....
