Need help identifying a headlight low beam issue
Old Jan 16, 2019 | 09:31 AM
JWest22's Avatar
JWest22
Default Need help identifying a headlight low beam issue
Greetings,
I recently purchased my second 2003 LS430 UL and have run into an issue with my low beams. The previous owner had installed a nameless brand $10 set of D2R xenon bulbs which is a problem on its own even though they are technically the correct bulb but for some reason one of the low beam connections has fried itself and essentialy exploded (see attached pictures). I don’t know if the fried wires are related to the cheap bulbs or if there’s another issue somewhere else. I’ve checked the lowbeam fuse and it’s fine and all other electronics work with no issue. I have a set of Phillips D2R bulbs but don’t want to install them till I kow it’s safe to put them in as they aren’t cheap. My guess is the cheap bulbs aren’t the wattage they say they are.
Old Jan 19, 2019 | 10:42 AM
BCT's Avatar
BCT
I am not seeing the picture. If the wires are fried, then you need to replace the wires before installing new bulbs.
aypues
Dec 28, 2014 11:47 PM
Golden95SC
Jun 18, 2013 07:09 AM
20GS300
Feb 19, 2013 04:17 PM
rcy
Feb 12, 2012 10:36 AM
Garymkrieg
RX - 1st Gen (1999-2003)
May 28, 2011 02:05 PM
