Door lock not working stiffs after I change Mabuchi motor
Old Dec 29, 2018 | 09:56 AM
Emani317's Avatar
Emani317
Default Door lock not working stiffs after I change Mabuchi motor
The door lock still not working after I change the mabuchi motor on driver side rear door. The door isn’t pulling closed either. What maybe wrong. That window Isn’t working either on that door.
Old Dec 29, 2018 | 01:06 PM
911LE's Avatar
911LE
Did you reconnect all the wiring?
Old Dec 29, 2018 | 01:37 PM
rkw77080's Avatar
rkw77080
Also check for blown fuses... Does the light on that door work? If not, look in the passenger-side fuse box and make sure the two 20A fuses called "RR DOOR LH" and "RR DOOR RH" are not blown.
Old Dec 29, 2018 | 03:16 PM
Emani317's Avatar
Emani317
all wires connected
Old Dec 29, 2018 | 03:36 PM
Emani317's Avatar
Emani317
no blown fuse
LexusJef
Oct 22, 2017 03:13 PM
khizr23
Nov 2, 2014 09:18 PM
krawfo
Jul 25, 2012 05:14 PM
fasted1953
Oct 29, 2010 02:52 PM
Proudvegan
IS - 1st Gen (2001-2005)
Oct 19, 2010 04:51 PM
