battery died. cannot get inside
Old Dec 5, 2018 | 10:38 AM
lexusls211's Avatar
lexusls211
Default battery died. cannot get inside
the battery has died on my 2006 ls430 and i am unable to open it, because i dont have the original door key. i had a key fob reprogrammed from another ls430. is there a trick to get power to the battery so i can open it with my key fob or a trick to open the hood while its closed. any suggestions without having to spend money on getting a key made at the dealer? thanks
Old Dec 5, 2018 | 10:43 AM
lexusls211's Avatar
lexusls211
is it possible to get power to the starter?
Old Dec 5, 2018 | 11:10 AM
911LE's Avatar
911LE
No, the starter is under the intake manifold and the wiring is not accessible from underneath. If you take your title to the dealer they will cut you a new door key.
Old Dec 5, 2018 | 12:53 PM
Johnhav430's Avatar
Johnhav430
Yep cutting a new key is the no muss no fuss solution...
Old Dec 5, 2018 | 01:06 PM
RA40's Avatar
RA40
Super Moderator
This Club Lexus vendor may be able to help you:
https://www.clublexus.com/forums/mem...ezcarkeys.html
https://www.ezcarkeys.com/main.sc
Going to the dealer will be faster and more $.
Old Dec 5, 2018 | 01:10 PM
rkw77080's Avatar
rkw77080
You can access the positive battery cable at the alternator from beneath the car. Just be very careful not to short the positive to ground.
Old Dec 5, 2018 | 03:57 PM
BCT's Avatar
BCT
Do you have AAA? They can help if you lock yourself out. Same scenario except the battery does not work, right? Unless maybe am missing something here.
If you are not member of AAA, I have seen local service who can open car door when you are locked out.
Good luck!
Old Dec 5, 2018 | 05:13 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
This may help
Old Dec 5, 2018 | 06:39 PM
lexusls211's Avatar
lexusls211
i wanted to thank everyone for their advice and suggestions. i was able to get the car opened using a battery charger on the alternator positive wire from below the car. instantly the alarm went off,but i was able to shut it off by pressing the keyfob unlock button constantly. this way i was able to get inside and pop the hood to charge the battery. i only had to remove a few clips and screws from the front passengers side of the bumper cover splash shield. Hope this helps anyone else in the future. Thanks!
Old Dec 6, 2018 | 07:15 AM
jonathanz's Avatar
jonathanz
very good info! thanks for coming back and update all!
Old Dec 7, 2018 | 04:24 AM
Legender's Avatar
Legender
Great work and nice idea to access from underneath. Now, go get that key made! LOL.
Old Dec 7, 2018 | 03:35 PM
Stu's Avatar
Stu
there is a key built into the key fob ... for just this reason.
Old Dec 8, 2018 | 11:00 AM
Duck05's Avatar
Duck05
Not a problem on an '01.... …..
marty99
Sep 25, 2013 10:24 AM
daryll40
Jun 8, 2013 09:25 AM
tgcLS430
Jan 17, 2009 06:23 AM
TreeTops
Aug 26, 2008 09:24 AM
Moogy
Aug 4, 2008 10:37 AM
