paint color difference
Subscribe
Aug 15, 2018 | 12:02 PM
i'm looking at 2 cars. one has crystal white pearl and the other is moonlight pearl. what is the difference or was it the same and just renamed?
Reply 0
Aug 15, 2018 | 12:34 PM
They are 2 different colors and have separate paint codes. To my eye, the former is a brighter white.
Reply 1
Aug 15, 2018 | 01:11 PM
I have the moonlight pearl, I honestly prefer it. It has a bluish tinge to it when viewed in direct sunlight, as well as the metallic flakes. It's really pretty nice.
When you go to do a touch up, most of the time you would need the base coat, and the mid coat. For tiny chips, one can get away with the top coat. I recommend moonlight!
The other white is flat....depends on what you prefer...
Reply 1
Aug 16, 2018 | 12:44 PM
I believe the crystal white is a single coat without the clear coat and is definitely more 'white'. I think the metallic pearl white used to be called Diamond Pearl and is my color of choice.
Reply 1
Aug 19, 2018 | 03:00 AM
Crystal White Pearl (aka Blizzard White) is code 070 and is pretty common throughout the Toyota range. Its a 3 stage pearlescent (just like any pearl white really, its not possible to have that effect as a single stage), Moonlight White is a Lexus only colour I think, and there is a big difference between the two. Crystal White is a lot cleaner and uses white pearl and silver white flake pearl in its effect layer, while Moonlight White looks a bit greener on the face in comparison. I've never sprayed Moonlight White before so I couldn't tell you what is in the effect layer
Reply 0
Subscribe
