How to replace this light
Old Aug 8, 2018 | 02:22 PM
drjls1963's Avatar
drjls1963
Default How to replace this light
How do you replace the light located on the trunk, labeled T10. I have take the light assembly off the car and cant seem to find how you get to the bulb. Its the top light on the trunk. Thanks for the help
Old Aug 8, 2018 | 03:27 PM
rkw77080's Avatar
rkw77080
Old Aug 9, 2018 | 02:56 PM
StanVanDam's Avatar
StanVanDam
Open the flap in the trunk to access, and if you can get your hands in there to rotate the bulb out, you don't need to take the assembly out. If you can't get your hands in there, then you have to undo the three 10mm bolts (see the gold pegs in the black area in the picture above) and the whole assembly will come out, just like that picture.
If referring to the license plate bulb, see https://www.clublexus.com/forums/ls-...ght-bulbs.html.
All questions relating to bulb changes have been asked and answered dozens of times in these forums. I would like to ask that the forum moderators start combining related threads so that information is easier to find. There are ~20 threads on air suspension that can be combined, ~20 threads on front brake rotors, ~20 threads on spongy brake pedal, a few threads on front wheel hubs, a few on rear wheel hubs, a few on engine oil, several on speaker replacement, dozens on "what to look for when buying a new LS430", etc.
I'm not saying combine all lighting-related threads (I know there already is one), as that would also make information difficult to search for. If someone wants to search "license plate bulb", all license plate bulb discussions should be in the one thread.
The LS430 is now old enough that the vast majority of questions have been answered, and we don't really need dozens of threads on the same topics. I think it would be a great community service to start combining threads that refer to the exact same component in the exact same location.
Old Aug 10, 2018 | 09:09 AM
Daspyda's Avatar
Daspyda
And here I was thinking it was LEDs...
Old Aug 10, 2018 | 06:20 PM
LS430inDE.'s Avatar
LS430inDE.
Excellent suggestion, and I concur.
Old Aug 14, 2018 | 05:09 PM
Ralo14's Avatar
Ralo14
I think on some models you can push up on the lens and slide it over and it falls out of the bottom of it's hole. On mine a trim piece seemed to be in the way so I went through the trunk by removing the lid liner.
250kGoal
Jun 28, 2012 09:51 AM
path
Sep 6, 2011 12:40 PM
RayLai417
Jul 11, 2007 07:59 PM
BlkGS3
Apr 5, 2007 08:44 PM
chicagoblknazn
Lighting
18
Oct 12, 2002 12:15 PM
