Major problem
Old 08-01-18, 05:23 PM
johnnylt
johnnylt's Avatar
Default Major problem
I m putting led lights in to replace reg ones all of a sudden no radio lights , gear shifter lights , snow light heater switch lights glove box all the lights around Navi, coin box lights there all out checked some fuses look good . What on gods earth went wrong ?
Old 08-01-18, 06:01 PM
rkw77080
rkw77080's Avatar
Please take look at a 7.5A fuse in the driver-side fuse box called "PANEL".
Old 08-01-18, 06:11 PM
johnnylt
johnnylt's Avatar
Thank you I don’t see a fuse called panel in the owners Manuel
Old 08-01-18, 06:14 PM
rkw77080
rkw77080's Avatar
Your LS is a 2005, right?
Old 08-01-18, 06:20 PM
johnnylt
johnnylt's Avatar
Yes 05 ls 430 omg I pulled the one right above it 20 amp ok thanks for the diagram I will pull and let you know
Old 08-01-18, 07:10 PM
johnnylt
johnnylt's Avatar
I pulled a lot of 7,5 fuses they all looked clean no breaks is this on drivers side inside or under the hood
Old 08-01-18, 07:17 PM
rkw77080
rkw77080's Avatar
It's the one inside the car.
Old 08-01-18, 07:35 PM
rkw77080
rkw77080's Avatar
I went back to look at the electrical diagram. It seems that the 7.5A "PANEL" fuse provides power to most of the illumination lights in the cabin. Attached is the electrical schematic I reviewed. Can you take a look at it and let me know if the lights shown on the schematic are the same one that are not working?
File Type: pdf
Old 08-01-18, 07:50 PM
rkw77080
rkw77080's Avatar
Old 08-01-18, 09:00 PM
BCT
BCT's Avatar
Not saying this is your problem, but I have had fuse where it looks fine but it is not working. This had happened to me more than one time. Do you have a spare fuse? Do you have another car that you can borrow/swap the fuse?
Old 08-01-18, 10:28 PM
Htony
Htony's Avatar
Visual check of fuse? No simple multimeter at hand?
Old 08-02-18, 03:09 AM
johnnylt
johnnylt's Avatar
Yes sir I have spare fuses I will try a new one and yes I have all interior lights working dome map lights door lights ,it’s all panel lights not working ,Navi ,radio all heat seated buttons , window shade , snow/etc , glove box, coin tray, gear shifter etc
Old 08-02-18, 04:45 AM
johnnylt
johnnylt's Avatar
Ok I took a better look this morning a lot lighter out my drivers side fuse box does not look like your picture there is no 7.5 amp fuse where yours is I put a picture on for you .
Old 08-02-18, 05:30 AM
LS430inDE.
LS430inDE.'s Avatar
It looks like there's a 10A in your picture where RKW's post shows a 7.5A! Check the 10A fuse, left column in your picture, 2 spots above your 30A or 2 spots below your 20A. Now the secondary question is why do you have a 10A fuse when RKW shows it's supposed to be a 7.5A? Hmm...
Last edited by LS430inDE.; 08-02-18 at 07:37 AM. Reason: corrected/changed post from "supposed to be 10A" to "supposed to be a 7.5A"
Old 08-02-18, 05:48 AM
johnnylt
johnnylt's Avatar
Yes that is what im wondering too , I have never touched this fuse box and everything had worked fine since ive had the car , I should of never messed with those dam LED lights , ok I will check that 10 amp fuse and see if its broken when I go on break
Quick Reply: Major problem
