03 LS - Difficult to remove electrical connector
Old Jul 28, 2018 | 07:29 AM
Arcturus's Avatar
Arcturus
Default 03 LS - Difficult to remove electrical connector
Hello,
There is an electrical connector behind the AC compressor on the drivers side. Down low but difficult to access. It is on the same harness as the connectors for the AC compressor. This has been an absolute nightmare to remove. Very difficult to see how it disconnects. And try as I might with applying pressure at all different locations it doesn’t want to budge. Anyone know how to remove this SOB?
thanks
Old Jul 28, 2018 | 08:04 AM
Johnhav430's Avatar
Johnhav430
My way of dealing with those situations, if financially feasible, is to buy the connector, so I can see what it is.
I know it sounds dumb but it happens even when you have access to connectors, and it's never good to force them...good luck...
Old Jul 28, 2018 | 08:33 AM
2KHarrier's Avatar
2KHarrier
Originally Posted by Arcturus
Hello,
thanks
You can use a small flat bladed screw driver and slip it in the lock mechanism, then use a second screwdriver to gently pry the connector off. Use it perpendicular to the connector and pry it off.
At least in theory, that should work....
Old Jul 28, 2018 | 10:18 AM
Arcturus's Avatar
Arcturus
I'll see if I can get you a photo of it. Even to get a photo is difficult. Small things like this always hold up jobs.
Old Jul 28, 2018 | 11:09 AM
pmesfun's Avatar
pmesfun
I use hose pliers or angled pliers to get like these.
Old Jul 30, 2018 | 05:16 PM
Arcturus's Avatar
Arcturus
Finally got it. Soaked it with electrical contact cleaner, then used a pair of long needlenose pliers (like the bottom pic except at 45 deg) to tug on the base. Thought I was going to break it but it came off without any problems.
Appreciate all the helpful suggestions.
Lonely77
GX - 1st Gen (2003-2009)
Jun 21, 2018 08:10 PM
texsexlex
Jun 7, 2017 03:09 AM
istundra
Jul 17, 2013 08:12 PM
tuninghaus
Apr 11, 2007 07:35 PM
JIC JZZ31
Sep 11, 2006 12:57 PM
