LED Taillight Repair
Old Nov 24, 2023 | 02:33 PM
  #61
cyclehead's Avatar
cyclehead
Default Fixed LEDs
I took apart my second (LH outer) taillight. It only had two burned out LEDs. I'm much happier with my solder joints. This one has a nice red exterior lens and no damage to the weather stripping. I think I'll offer it for sale/exchange to somebody that has burned out LEDs.
I made two splices with aluminum sheet and epoxied two spots where screws wouldn't work. Then sealed the cut with silicone.
Can I post For Sale in this sub forum?
Attached Thumbnails LED Taillight Repair-img_0108.jpg   LED Taillight Repair-img_0110.jpg   LED Taillight Repair-img_0117.jpg   LED Taillight Repair-img_0124.jpg   LED Taillight Repair-img_0114.jpg
LED Taillight Repair-img_0115.jpg   LED Taillight Repair-img_0116.jpg   LED Taillight Repair-img_0125.jpg
Old Nov 30, 2024 | 01:59 AM
  #62
Lkwdryan's Avatar
Lkwdryan
2nd gear
Default Taillight ASM. I would like it, assuming you still have it as unlikely as that may be
Originally Posted by CA2WALS430
Hey handy people, do you want my fritzing LED tail light? It sounds like some of you may know how to fix them. I just bought the new one for $200, but I am a big fan of recycling so if you would like mine to fix and use on your 04-06 LS, let me know.
No charge of course; I will ship it to you.
Right side (passenger) trunk mount, 81581-50050. Visually perfect condition, no fade and not a scratch.
I would love to get your tail light assembly, unlikely as it may be, I thought I would check to see if it was still available
Old Nov 30, 2024 | 08:12 AM
  #63
rael's Avatar
rael
I checked with him 2 days ago and he's currently out. I bit the bullet and bought one at Bell Lexus for $260 delivered
Old Dec 2, 2024 | 06:40 AM
  #64
CA2WALS430's Avatar
CA2WALS430
Thanks, @Lkwdryan ! That post was a while back and I already sent it out to a member on the site here. Good luck. I paid $150-ish at Bell for my last one and Amayama would likely have them too. The install is 3 bolts and about 15 minutes.
Old Apr 16, 2025 | 02:45 PM
  #65
Corchid's Avatar
Corchid
1st Gear
Just want to say I'm really impressed that this thread exists and has an actual solution with pictures and a summary. Thanks to everyone involved
Old Apr 18, 2025 | 12:49 PM
  #66
CA2WALS430's Avatar
CA2WALS430
I am pretty incompetent in the DIY, but thanks to this site I discovered in 2014, I have impressed myself several times! Just remember the best way to search is to go to your main Google page and just type in "LS430 blah blah blah (briefly state problem)" or "clublexus LS430 blah blah blah".
This site is an amazing resource. You can also find at least 5 great sources for steep discount OEM parts.
Old Jun 25, 2025 | 11:30 PM
  #67
pur's Avatar
pur
My inner tail lamp flickers for over 3 years and now finally darked.
I did three tests so far.
Test number one - individual component. I metered all resistors and diodes. The 82ohm resistor read OL. Other resistors all read per the writing. All three diodes are at 0.54v. My meter has no capacitor function unfortunately.
Test number two - power test. The three wires input are black, red, white. The four wires output are orange and blue being common ground and the yellow and brown being common positive. Run A: input 12.48v, feed to black and white, both pairs of output 12.17v. Run B: input 12.44v, feed to black and red, both pairs of output 11.8v.
Test number three - directly feed the internal LEDs with external 12.48v power source (connect to blue/yellow and orange/brown). AKA bypassed the board brake vs night diming function. No light at all.
Logically, shall I go ahead and cut open the lamp assembly and replace the LEDs since test number two and three suggested the LED not led. But my test number one is not a all pass although I worry the surface corrosion prevent my metering on the 82ohm yet other resistors all metered. Any thoughts? Thank you.
Old Jun 26, 2025 | 06:08 AM
  #68
weldthedif's Avatar
weldthedif
does anyone know if the older pre-facelift tail-light assemblies can be swapped in for the LEDs ?
Old Jun 26, 2025 | 06:29 AM
  #69
alextv's Avatar
alextv
You need to verify the 82 ohm by desolder and pull up 1 end. Also to me the cap looks more like an mov to me and make sure not shorted. You did have it unplugged right?
Old Jun 26, 2025 | 09:58 AM
  #70
pur's Avatar
pur
I don't mind to go ahead and replace the resistors as they age. A local source has both 82ohm and 1.3ohm 1w for less than $1 on a pack of 10. Driving there in contract is $10 of fuel and 2hr of time in Vancouver traffic. My concern is the test number 3 fail which is the direct 12v source to the LED without any flicker or weak light. Since LED has no internal resistance, meter won't help. If I must replace the LEDs, shall I replace the LED before massing with the resistor believing the test number one results in 11.8v and 12.17v output. The function of the board seems right although one resistor cannot be tested at the moment? Or the 11.8v and 12.17v cannot confirm the full function of the board?
And yes, the light was inspect on my desk with a 12v wifi router power adapter measured at 12.4x volt.
Old Jun 26, 2025 | 10:24 AM
  #71
pur's Avatar
pur
I am having a second look and it may be too premature to judge the R1 82ohm. What is 182J 39?
Old Jun 26, 2025 | 10:27 AM
  #72
alextv's Avatar
alextv
Don't replace resistors for the heck of it. LED is just an light emitting diode and you can check it like a diode. Verify the 82 ohm.
Old Jun 26, 2025 | 10:41 AM
  #73
pur's Avatar
pur
Ai is so cool. Set my meter to 2k ohm range. R1 measures at 1.81K ohm. So, all resistors are good. The LED is the only fault now. Gotta replace the LEDs inside.
Old Jun 26, 2025 | 11:03 AM
  #74
alextv's Avatar
alextv
Pull it up and measure and check leds as a diode. Also I don't see that as 182J so measure and if 82 or 1800 it is fine and if bad check the other side of car for value.
Old Jun 26, 2025 | 11:23 AM
  #75
alextv's Avatar
alextv
Also if it is 1800 ohms that means those leds are not 12v and applying 12v could have damaged them. By looking back at this thread the leds are 1.75v.
